In these new fangled ice boxs is what you call adaptive defrost
control. Instead of the old tried and true defrost timer, brainiacs
have decided to use artificial intelligence to determine defrost.
The basic pattern of adaptive defrost is:
COOLING,PRE-CHILL,DEFROST,DWELL,and POST-DWELL.
Hey
I ain't making this up. The ADC (adaptive defrost control) Counts the
number of times the doors are opened, the total compressor run time,
and the length of time the defrost heaters were on during the last
defrost. This method supposedly enables the adc to work nice in all
kinds of conditions, whether hot and humid or cold and frigid climates.
COOLING Mode will remain for an indefinite time or until defrost is
determined by the micro-processor. When all systems are go for defrost
the adc makes the jump to light speed by going into PRE-CHILL, this
brings down the temps in the freezer to off set the defrost operation
so that the food temp does not suffer dramatic temp rises. Pretty cool
ain't it? If the ice box is in pre chill and the door gets opened then
a DEFROST HOLD OFF will jump in and not do a defrost for several hours.
If the door is continually opened at the end of 16 hours the adc is
gonna defrost that ice box anyway. The defrost period varies but is a
maximum time of 45 minutes including when the DWELL kicks in. Dwell is
the length of time the ice box stays off AFTER the heater is terminated.
Then
The POST DWELL will kick in. The post dwell will fire up the compressor
and condenser fan but the inside fans will not run allowing the coils
inside to cool down before them fans kick in and she jumps back into
Cooling mode. I bet you would like to have a copy of GE's adc repair
manual wouldn't you?
TECHNICAL SERVICE GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
