LG WM2277H Front Load Washer Logo
Posted on Dec 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code FE
The machine stops about 30 minutes into a longer cycle. Cna finish of by setting quick cycle. Error code FE and a bit water leak.
Danny
Level 2:
Sergeant:
  • Expert 160 Answers
  • Posted on Dec 22, 2009
Danny
Expert
Level 2:
Sergeant:
Answers
160
Questions
0
Helped
63235
Points
538
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
I have an lg washing machine model wm2301hr. About 15 minutes into the wash cycle I got an error message EE. Since I couldn't resolve the error I pushed drain/spin and water leaked onto the floor.
First if the error code is "EE" then unplugging unit from power<waiting a few minutes and then plugging it back in might reset control board.
Second, are you sure it is "EE" and not "tE" or "fE"?
good luck
LG washer dryer WD1485RD showing error code FE. Will not stop pumping water into machine/ cannot finish the cycle
Try first unplugging power cable for two minutes, this can clear error code if there is no real problem with your appliance.
Halfway into wash cycle fe code appears, we can select drain & spin cycle and it will finish. how do we fix
The FE error code indicates an Over Flow Error. The machine thinks that the water level is too high in the tub.
There could be three causes to this problem.
1. The water level sensor is bad.
2. One of the solenoids is bad, either hot or cold.
3. The main circuit board is bad.
2answers
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
1helpful
2answers
Cycle stops and the code FE appears and to refer to manual but I don't have one, can you help
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
Must be some sediment in the water level pressure hose. Blow out the sediment, reconnect the hos, pump out the water and retry. This is an lg washer. You may only need to set or reset the water level frequency. I have service manuals and notes HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
MILDEW SMELL COMES FROM WASHER
. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
4helpful
2answers
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
14helpful
2answers
F-H code and water won't stop
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
