Washing Machines Logo
Anonymous Posted on Dec 20, 2009
After the wash cycle is complete and the clothes are removed, the washer will slowly fill with water. We let the machine go through the drain cycle and the washer slowly fills up with water again. Any solutions?
Anonymous
Level 3:
  • Kenmore Master 3,361 Answers
  • Posted on Dec 20, 2009
Anonymous
Kenmore Master
Level 3:
Answers
3361
Questions
Helped
1029787
Points
10654
Your water fill valve is defective. This is a fairly common problem.
This video,while not specific to the water valve will show you how to remove the cabinet to access the water valve.
The water valve is the part the water hoses connect to.
http://www.youtube.com/watch?v=WLPGs2UMUJc&eurl=http%3A%2F%2Fappliancejunk.com%2Fforums%2Findex.php%3Ftopic%3D67.0&feature=player_embedded#t=15
Testimonial: "Very quick and accurate response. Thank you very much. The part is removed and I'll find the replacment part tomorrow."
Fisher & Paykel GWL11 will not complete full cycle, and beeps with wet clothes and water in the tub. The drain pump runs, but drains water very slowly.
This machine will beep and stop washing when the load is out of balance. Have you tried removing the clothes and lying them in again (carefully) and pressing the START/PAUSE button to complete the wash?
My washer completes the cycle just fine but after I've removed the clothes, the tub slowly fills with water. This happens even when the machine is off. Is it a valve or drain problem?
well if theres more water in it now then when you took clothes out , id fail to se how its a drain issue , no id lean towards the inlet solenoid valve have a small bit of debris keeping it from closing all the way , this will probably need replacing
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
2answers
Kenmore HE3t Frontloader Fills Up With Water After Cycle
Does this change if you select a cold wash or a hot wash? What's the water temperature feel like when it fills? I'd suspect the water control solenoid for either the hot or cold water isn't shutting off completely. This could possibly be due to a piece of debris or mineral deposit in its seat, and could be cleaned with CLR or citric acid if you remove it. They're not very expensive and not a very hard item to change on most machines.
3helpful
2answers
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
2helpful
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
1helpful
Water backs up into washing machine after washing a load.
check your drain hose and drain pipe,if not that then i think your inlet water valve is not closing all the way,try it on cold only see what happens,then try on hot only see what happens,let me knoe what you find-mike
Ariston awd121 washer will not complete wash cycle
I'm also having the same problem. I hate this machine!
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Alexander
vince
