All-Pro K175 Heater Logo
Posted on Dec 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit turns itself off after a minute - All-Pro K175 Heater
Anonymous
Level 3:
Prodigy:
An expert who has answered 500 questions.
  • Master 540 Answers
  • Posted on Dec 21, 2009
Anonymous
Master
Level 3:
Prodigy:
Answers
540
Questions
Helped
190234
Points
1000
This is a safety design, now find out why did it tripped? or it time for a full service or overhaul, like plug-- fuel filter --- 2-- air filters vanes in the pump assembly which you can buy at your local lawnmower repair shop!
TV - Mitsubishi WD-62530 Will not power up unless first unplug from wall for approx. 15 minutes prior to turning it on or it will not power up at all).
Start with changing the capacitors that look bad on the PS board...I think you will find some that are bulged when you take the cover off, should be a easy and cheap fix
When the air conditioner goes on it shows "E2"and nothing else happens what can be done to solve the problem?
The E2 Code, indicates a Sensor or System Failure, But, before calling Haier, try this.
Turn the Master ON/OFF Switch to OFF & unplug the unit for 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the unit's electronics during that 15 minute timeout, have reset itself and reverted back to the original factory settings. If so, it was a false code. If it didn't reset itself, contact Haier Customer Support 1-877-337-363.
Hope this helped you. Please let me know.
1helpful
I turn my unit on with the TV and it runs for about 15 minutes an then the unit turns itself off. I turn it back on and it last about 3 seconds and turns back off. Unit is not hot and is 4 years old.
CAPS (capacitors) on the power supply board are going bad. TV putting itself into fault protection by turning itself off..... If you can give the model number I can better help you.....
When you turn it on it does not work it just blinks and blinks
You can try to get it to reset itself by doing the following:
Turn the Master ON/OFF Switch to OFF. Unplug the unit and leave unplugged for 12 - 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, the 12 - 15 minute timeout, allowed the unit to reset itself.
Generally, this works 90% of the time. I hope it works for you.
2answers
Turning off in 2 minutes automatically
My guess is that the fans inside the computer have stopped working, thus leading to the overheating. AMD processors generally run "hot" (50 to 60 degrees Celsius) even with proper fans.
Take your computer to a qualified technician, for a cleaning, and proper trouble-shooting, and repair, before the overheating causes permanent damage.
2helpful
1helpful
Garmin C330 resets itself
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Top All-Pro Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
