Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
Posted on Dec 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RE: Roper RT18DKXKQ the condenser goes off as it should when the fridge hits the desired temp. but then it will not come back on unless i move the thermostat to a new setting. sometimes i need to turn the thermostat all the way off and wait a minute before turning it back up and then it comes back on. the condenser seems to be working fine once it begins to run. thanks for the help - rick
Dan Webster
Level 3:
  • Roper Master 8,221 Answers
  • Posted on Dec 19, 2009
Dan Webster
Roper Master
Level 3:
Answers
8221
Questions
5
Helped
2380683
Points
25840
Time for a new cold control. That thermostat kills the power to everything, Their are only 2 wires and a ground. Pretty simple to swap out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sal De
Level 3:
  • Roper Master 2,699 Answers
  • Posted on Dec 20, 2009
Sal  De
Roper Master
Level 3:
Answers
2699
Questions
0
Helped
1003137
Points
8029
Thermostat number 2204605,there's also an adaptive defrost board in this unit part 2304099,i'd start by changing out the thermostat first,
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
244
Points
Roper RT18DKXKQ the condenser goes off as it should when the fridge hits the desired temp. but then it will not come back on unless i move the thermostat or tap the side of the control area and wait a minute before it turn back on and then it comes back on. the condenser seems to be working fine once it begins to run. thanks for the help. Jose
Rt18dkxkq roper refrig..9 yrs old..blowing warm air freezer and refrig....turned refrig off to totally defrost for 24hrs in case freeze over..still same problem..i hear a click every so often..maybe every...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The refrigerator in my new home is Roper RT18DKXFN01, a 1997 top freezer about five feet tall. Should I be pulling out pans from the bottom and cleaning them? If so, I can't get it to move - is there some...
Hi ; Not an expert on this fridge,
You do not need to clean the coils
But at the back of the fridge , there should be a water trap sat on top of the compressor that is linked to the fridge via a pipe.
It allows condensation to run out of the fridge to the trap, where the heat from the compressor evaporates it.
Its possible that food waste has travelled down the pipe into the trap and is creating tha bad smell
You could also check the back for anything else that may have arrived by default and is causing the smell
Not sure if it has a special way to move it : But its a heavy object , so a little extra force may be needed.
Take care and good luck
Top freezer works but the lower part of the refrigerator get warm
Check your evaporator fan in freezer, you can here it and feel the air flow into fridge, if you are not getting air into fridge it is either your fan or you may have ice blocking the vent into fridge.
2helpful
Frige icing up every 1 or 2 days roper
Hi, more then likely it would be the defrost timer that is causing you're problem. On some models they are located at that back bottom corner, mounted with a couple of screws.If you can't locate it, look at the schematic on the back and look for DFT and locate it from there. This will be the problem. Defrost timer failing.
Best of Luck,
Shastalaker7
1helpful
Refrigerator not cooling properly.
upper part feeses and bottom not verry cold at all
Refrigerator hardly cold freezer not freezing
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1helpful
Refridge leaking water inside it...
Should be a little drain hole in the bottom rear of the fridge. Use a pipe cleaner or somthing similar cos it,s probably blocked. Quite a common problem.
Roper refrigerator--water accumulating in bottom of fridge
on some refridgerators the plug at the bottom inside either turn out or lift up,be gentle either way,probably plugged just under it
2helpful
2answers
Fridge is not cool. Freezer has soft ice buildup inside
Your website is fantastic... it really helped me and saved me money!!!
I defrosted my fridge overnight. Cleaned all the water up. Plugged the fridge back in and it works likes new. Thanks :):):):)
Top Roper Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
