WE HAVE DRAINED THE WATER AND CHECKED THE PUMP CAP AREA AND THERE IS NOTHING IN IT. OUR MACHINE IS A BOSCH AXXIS WFL 2050 OR 60 NOT SURE WHICH- IT IS STOPPING AT THE DRAIN CYCLE AND THE DOOR LOCK AND RINSE/SPIN LIGHTS ARE FLACHING, WHAT COULD THE PROBLEM BE?
Check the drain pump, look for debris. have a shop vac and some towels, also unplug it for safety. Access the drain pump on the front lower right corner. Bosch washers usually have a panel that is circle shaped. stick a paper clip in the little hole and rotate the circle counter clockwise. From there, the drain has a cap that can be unscrewed off. water will come out, so have a shop vac and towels handy. remove all the bad stuff that shouldn't be there. Usually you will find change.
Bosch washing machine WFL2060UC
This video will show you how to change the pump washing
machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace [email protected] , [email protected]
suspect you have filter blocked or a foreign object in pump.
put drain hose as low as possible in a bowl and drain as much water as you can
undo filter but be carefull, water will come out in considerable quantities.
clean filter
check nothing stuck in pump impellor
