Our GE sss25kfmdww side by side fridge stopped cooling. We vacuumed the compressor and hair-dried the panel in the back of the fridge (after removing the cover.) After a couple days, it's stopped cooling again. Repeated the process....works for a few days, then freezes up.
Most times on that model the defrost heater and defrost thermostat will need to be replaced. The timer is built into the mother board and for some reason they are not the most likely reason. The defrost heater has a glass tube around the element and easy to spot if burned out. If you replace one part you should replace both. Now is a good time for you to do a little reading about your model. I will give you a link to the service manual and a page with a tech sheet, Sea Breeze
Here is a link to the tech sheet and manual=> GE Artica Profile Technical Information While on that page about midway down download the service manual.You models mother board is sensitive to electrical surge and fan failure will damage the board also. At this time I think you will be fine once the defrost components are replaced. here is a photo of defrost heater part number Click Here=> WR51X10055 and the defrost thermostat part number Click Here=> WR50X10054
If you still need assistance, contact me here at Fixya or through my site HERE or here Sea Breeze Appliance Parts feel free to ask any time, Sea Breeze
