You will need to go into your system BIOS and disable the Chassis Intrusion Sensor. BIOS is accessed by pressing the "del" key during the initial POST screen (or when giant Asus logo is on the screen) .
Look through there and located and disable the chassis intrusion sensor. If you can't find it, reference your manual for the board. If you don't have one, one can be downloaded in PDF format from the Asus website.
Be careful when in the BIOS, changing anything to an incorrect value could render your system useless! Don't play with anything, unless you explicitly know what you are doing, and what the setting does...
Be sure to "Save and Exit" in order foe the changes to stick.
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
Hope this helps
