Dryers Logo
Posted on Dec 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore series 90 electric dryer: exhaust air is
Kenmore series 90 electric dryer: exhaust air is obviously bypassing internal lint screen...large amounts of lint clumps coming out the outside vent.
Sal De
Level 3:
  • Kenmore Master 2,699 Answers
  • Posted on Dec 18, 2009
Sal  De
Kenmore Master
Level 3:
Answers
2699
Questions
0
Helped
1002382
Points
8029
That's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
2answers
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
My kenmore 60 series gas dryer stopped drying clothes.
Check for restriction in lint chute, blocked exhaust tube, plugged lint screen
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Kenmore 90 series electric dryer. Buzzez when you press the start. Sometimes it runs for a couple minutes then shuts off. is this the motor or a start capacitor?
Thermostat controls heat. There is also a motor centrifulgal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
90 series dryer won't stay on
UNplug the dryer, pull it out from the wall, and remove the service panel. Use a flashlight and look around for signs of anything having burned, and smell around to see if you can identify what might be burning if you can not visually see any burning.
If you plug the unit back in while your back there, have someone start the dryer and see if you can see what might be the problem.
I am suspect the motor may be failing, but it's hard to see what's happening through these teeny-tiny little wires.
Reply back what you seeing and we can help you further.
My Kenmore 90 Series Dryer keeps overheating. I've cleaned out all lint I can find in the traps, the exhaust vent leading out, and even popped the bottom panel off cleaning that area out. Is the motor...
By overheating I presume you mean the high temperature fuse is tripping.
The two most common causes are poor air flow and a bad themostat. If there's a good flow of air coming out of the exhaust vent then it's likely the thermostat. Expect to pay $20-30 plus labor for a new one.
Check lint screen come on
Check the tubing the lint goes through (exhaust). This may be stopped up or clogged. There is a build up here of heat or something that is preventing proper air flow.
2answers
Kenmore 600 series electric dryer
start outside at exhaust hoot look for blockage there first look for steep dip or drop in line where condensation can acumilate
1helpful
2answers
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
