Garden Logo
Posted on Dec 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal kit? Faip 193490.
Brad Wilkinson
Level 2:
  • Expert 106 Answers
  • Posted on Jan 02, 2010
Brad Wilkinson
Expert
Level 2:
Answers
106
Questions
Helped
129791
Points
340
Alot of people have tried doing this as the genuine o-ring and seal kits are so expensive and sometimes hard to source, but many companies make orings and seals that are unique and cannot be found aftermarket,
If you are lucky you may find some but the only way of doing so would be to take the actual seal and orings down to your local bearing and seal supplier and they will measure it up and do their best to find some for you...
Regards
Brad
  •  Bob Oppenheimer
    Bob Oppenheimer Oct 12, 2013
    MSC industrial www.mscdirect.com sells metric O-rings by the bag. If you measure what you've got, you can make an educated guess what to replace with
Bob Oppenheimer
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Oct 12, 2013
 Bob Oppenheimer
Contributor
Level 1:
New Friend:
Answers
13
Questions
Helped
7568
Points
25
MSC industrial www.mscdirect.com sells metric O-rings by the bag. If you measure what you've got, you can make an educated guess what to replace with.
1helpful
I replaced water seals and now i have an oil leak. however i have good pressure
I don,t nothing by the brand of this pressure washe but i think there is also a large round oil seal is maybe broken or is not good or ring is not in his seat. but a cuff-kit has most times has not the 3 oil seals on the pump cover under the brass pumphouse this are the first rings simmer rings but before you have no problems with oil leak , are they not forget ? look carefully on the image of the cuff-kit or on the site of the brands models spares . if the brass pumphouse was released then you have replace the 3 simmer rings oil seals yet.
1helpful
What kind of pump oil
What you have is a generic pump from china more than likely. Its built along the line of a FAIP pump. They arent supposed to have the oil changed in them at all. Most are sealed pumps but may have a plastic plug in it. If you must replace the oil then I would suggest Pressure washer parts catalog quick links Pressure Washers High Pressure... and get this item 4.5 OZ. AR64545 OIL FOR AXIAL PUMPS. It is recommended for pumps built similarly but not for your specific pump. But it should work. Good luck. W
Ball valve spring pressure washer detergent line
Not sure what type pump you have but you can buy a chem. injector rebuild kit at Pressure washer parts catalog quick links Pressure Washers High Pressure...
If you need to replace the spring then replace the entire kit. Ball, spring and oring. Most pumps that come on the newer TRoy bilts are AR RMW pumps. the parts diagram can be found here at http://www.arnorthamerica.com/manuals/rmw-om%201006.pdf
The parts for a AR chem. injector are
480480 O-Ring
1250280 Ball
1560520 Spring
Good luck
2answers
Power washer not spraying hard
Hi Mike
You could have one are two problems with the pressure washer.
1...pump for pressure washer worn and needs washer/seal replacement.
2...Need to adjust the pressure discharge relief valve to the needed pressure.
Please take time to rate me
Bud
020209 pressure washer has no pressure
Your water inlet may be stopped up. Whether this model only has a screened hose washer or a better filter, pay special attention to that. Be sure the pathway is free and clear.
Take each of poppet valves and while pushing (with a pencil or something) on the part that moves up and the spring pushes it back down - with magnification and lots of light, be sure there isn't a small piece of debris affecting one of those valves. Its easy to miss, so look very closely.
Next, remove the hose from the pump. We are by-passing the entire unit that includes pressure hose, trigger gun, lance, spray nozzle. If it seems to pump a lot of water out of the pump--then the problem is most likely the trigger gun is clogged or the pressure nozzle is clogged. Some trigger guns can be taken apart -- some, not so much. Same with nozzles.
I hope this helps you, Randell. If yes, please take a sec to rate me. Thanks!
Don
Mar 23, 2012 • FAIP Garden
5helpful
Good evning. the problem with my washer is. the pump pulsates when trigger is released. I have a good pressure supply to the unit . help please.
it sounds like the seals in the pump are worn out.if you can purchase a replacement seal & o'ring kit you can do it yourself.get the model number and buy the kit to suit.dis asssemble the pump and replace the o'rings & seals.assemble pump and test.
1helpful
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
No pressure in power washer.
usually you can get a seal kit for your pump. I would need the model number to direct you to the parts you need.
Sep 03, 2009 • Garden
Where can i find pump rebuild kit for simpson pressure washer? i need o rings and seals
There are so many sites like ebay etc..
The best one is :-
http://www.pressurewashersupplies.com/
Check and let me know, if doesn't find the kit.
Thanks for using "Fixya".
Jun 23, 2009 • Garden
Top FAIP Garden Experts
Jay Finke
Jay Finke
john h
Are you a FAIP Garden Expert? Answer questions, earn points and help others
