Dean Baby V Electric Guitar Powder Logo
Posted on Dec 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does not work
We took out the 3 way switch to replace it and cant figure out how to make it work again
Fred Yearian
Level 3:
  • Dean Master 5,603 Answers
  • Posted on Dec 19, 2009
Fred Yearian
Dean Master
Level 3:
Answers
5603
Questions
Helped
2250322
Points
16163
Find a diagram searching this site for one that matches your configuration:
http://www.guitarelectronics.com/category/wiringresources/
I cant get footswitch to bypass
okay James - this is a long shot but I wanted to at least give it a shot. I've copied a bit of text I found from a users forum for Helicon. And is there software to be updated?
The footswitch must be plugged into the unit before you power on.
https://music-group.force.com/musickb/search?name=tch&q=switch-3
God Loves You!
Nov 21, 2017 • The Music
Just bought the mixer and cant figure out how to get sound to the main speakers, i have the apms correctly hooked up and speakers also
Since you posted this question nearly 3 weeks ago, I expect you figured it out by now - in which case, please mark thread as "closed".
If you are still trying to figure it out, please reply with the following information:
1. Make and model of mixer
2. What you are using as a signal source (mic, instrument, etc.)
3. Make and model of your speakers (important if they are self-powered, or not)
We'll take it from there - but a couple pictures will answer a lot of questions in regard to gain structure, signal path routing, buss outs, etc.
May 21, 2016 • Music
2helpful
2answers
No sound coming out of my mackie
Whether you are experienced in electronics repair?
if not, try this simply way:
1: Test whether the power amplifier is still working. See figure 1.
Power OFF,adjust the EQ settings as shown in the picture.
Minimize LEVEL.Switch ON Power. Touch pin 3 at the INPUT socket by using a small screwdriver or piece of wire / cable.
Slowly raise the LEVEL,a little bit only (as the clock showed 7-8) until
sound is heard in speaker. If not heard, slowly raise again LEVEL.
If audio input signal is heard,it can simply be taken to mean
that the amplifier is working.
If LEVEL at 9 o'clock position,and the audio is not heard,
the possibility of the amplifier is damaged.
Switch OFF the power. Take it to a repair place.
2: When the Power LED is lit, but no sound,
There are many possible causes, one of which is:
I have been getting 3 times similar cases, and all are caused by
two Rectifier-Diode (either or both.) damage on the power-supply-unit.
Remove/desolder,measure, if damaged replace it with a new one.
See figure 2-3.
Hope it helps. Regards.
1helpful
I have a Digitech wammy 4 v pedal the led light are going out i have 3 lights left how can i fix the led light the pedal works fine with out the lights
Check the burned out LEDS with a 3 volt battery- a computer bios battery works well for these.
If they do not light, which is likely, just replace them with similar sized units. You can even change their color too. Measure the voltage at the LED sodler pads to see if it is more than 3 volts, if it is, add a resistor to drop the voltage and limit current to the replacements. Digikey sells them, and they ship around the world http://www.digikey.com or Mouser, Both are based in the US, I am not sure what Mouser's international shipping is. http://www.mouser.com
If there is no voltage at the LED pads, look for bad solder connections, or burned out resistors. If the few remaining LEDs still operate as they should, the level meter chip "should" be okay.
I bought a yamaha electric it has two double pick ups and a single in the middle the volume knob was no good so i changed it when i opened it up they had the wiring all messed up it has a five pos. switch...
my guess is two positions at one end work(aka 1 and 2, or 4 and 5)? if yes, then 2 of the pickups are wired wrong. (if 1 and 2 work, which are the forward positions, then the middle and bridge pickup are wired wrong, etc.) the problem is there is a variety of 5way switches that are different. i would guess yours is "import" style. are there 8 lugs in a single row on the back of the switch? if yes, you probably have an import switch. best i can do in text is tell you that the middle two lugs are common. this means one goes to the volume pot, and there is probably a little jumper between the two lugs as well. now there are 3 lugs on either side of those 2 common lugs. one set of 3 will probably run to the tone pot in some fashion or be empty. the other set of 3 lugs is for the pickup lead wires. it sounds like at least one or two of those lugs are empty but shouldnt be, or are wired wrong. i cant tell you colors of your wires without seeing it, but this is how it should be, with the exception that the tone knob will probably be on the bottom 3 lugs somewhere. 1 would be the neck pickup, 2 the middle, and 3 the bridge hope this helps, feel free to post a pic of your wiring, etc xadioriderx.jpg
So my phaser was working fine untill I was using it one day and the modes kept switching on there own. This has been an ongoing problem to the point were I cant even use the pedal because the mode keeps...
I would SUSPECT that the power connector MAY be loose and when you move the pedal it breaks connection momentarily.causing the pedal to lose track of where it was. This could ALSO be bad solder joint on the board, aften near the power inout connector.
The pedal is shorting out, it seems to be the Level dial. I took the back off of the pedal and cant get the insides out because the inputs are attached to the circuit board and I cant figure out how to get...
SORRY I DON'T HAVE A SOLUTION BUT I COULD REALLY USE A PICTURE OF THE INSIDE OF THAT UNIT.:( I MADE THE MISTAKE YOU INDICATED YOU DIDN'T WANT TO MAKE IF YOU COULD HELP I'D APPRECIATE IT.
5helpful
3answers
Marshall MG250dfx's sound fades out
I have read that the problem is in the FX send/return jacks which oxidize if not used much. All you have to do, apparently, is ram a jack plug in and out a bunch of times. This breaks up the oxidation, and allows the amp to work properly again.
2helpful
Got a 5000 euro power the output module has gone i think as it turns of after 2 seconds can you get a replacement part copy
I had to repair mine. An arc had occured between circuit traces and a heatsink in the power amp and that took out a half dozen transistors, a switching regulator chip, two power resistors, diodes. The parts are all available BUT you must be very careful to weed out ALL the bad ones.
AFTER repair, put a 150 wat light bulb in series when powering up to avoid damage IF there still is a bad component in the circuit.
After cutting out the damaged board and replacing the parts it is all working again.
I had to trace out some of the circuit to troubleshoot as Behringer won't give out schematics.
The amplifier in this is a class "D" switching type. Be very careful of running the unit if the speakers are not connected.
Top Dean Music Experts
ADMIN Eric
ADMIN Eric
Tahir Hussain
Tahir Hussain
umar waheed
Are you a Dean Music Expert? Answer questions, earn points and help others
