GE WBVH6240F Front Load Washer Logo
Posted on Jan 22, 2008
WATER LEAKING FROM FRONT BOTTOM
WATER IS POURING OUT FRONT BOTTOM OF WASHER. CHECKED HOSES, ALL ARE TIGHT, NOT LEAKING FROM THERE. WATER COMING FROM EACH FRONT CORNER. THANK YOU!
  • 2 more comments
  • Anonymous Mar 20, 2008
    I hate this washer.
  • Scott Tankersley May 26, 2008
    Have a ge washer that leaks out the front. It acts like the seal is not sealing with the door. Model no. wbvh6240fww
  • Anonymous Jun 01, 2008
    the rubber sealant has tear in it
  • Coach Andy Jun 13, 2008
    Our 5 yr old whirlpool washer had water filled in the drip pan, over flowed and seep through floor board. We have a dry wall mess now on the second floor. QUESTION: Obviously the drip pan is there for a reason, ours had separated from the drain pipe it was connected to. Would normal "drippage" cause that much over flow???
Scott Tankersley
Level 1:
  • Contributor 4 Answers
  • Posted on May 29, 2008
Scott Tankersley
Contributor
Level 1:
Answers
Questions
Helped
2215
Points
Hey guys and girls. I found the problem the soap dispenser tube popped out of the gasket and was leaking behind the gasket and running down the front. It was pretty easy to take apart the unit. I can also offer this tip. Cut the hose off of the soap dispenser piece.
Pull the tube through the hole in the gasket and reinstall the soap dispenser and carefully pull the hose back to re-seat the soap dispenser.
A
Anonymous
Check your door boot, ours is doing the same thing. Found out there's a huge hole in the door boot seal.
A
Anonymous
Try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
I have a leak at the front bottom of my lg front load washer
this most likely is coming from the pump assembly which is located on the front... make sure the clean out filter lid is tight and nothing is leaking from there... make sure you have no tears in the door liner /rubber boot... your going to have to gain access to inside of unit to inspect and see where exactly the water is coming from ....it could even be comning from one of the hoses that go to your dispenser area as water does go through there during operation..... good luck to you....
3helpful
2answers
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
1helpful
Kitchenaid topload washer about 3 yrs old, started leaking from bottom, front. Checked hoses at faucet and washer, all tight no leaks there. Seem to be coming from under the front lower lip of washer.
it's the pump. release the control panel and flip back on hinges. pop the retainer clips and unplug the lid switch harness on top. pull entire white part of cabinet back and up..pump is front center.
1helpful
Leaking water
Your pump is leaking. it is attached to the front of the motor. Very common. Pump retails around $60.
Part number is 3363394
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
2answers
2answers
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
