Euro-Pro Shark GI490 Iron Logo
Posted on Jun 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I purchased a Shark G1405Z iron on 7/22/09 at WalMart. I was pleased with it until this past Friday. I was ironing dress slacks and noticed it was hotter to the touch than usual. A few minutes later it completely shut off and I have not been able to get it to work since. I am sure that the electric breaker did not shut off since I am able to run other appliances from this same outlet. Please let me know if there is something that can be done.
Pamela Leach
Level 3:
  • Master 1,830 Answers
  • Posted on Jun 28, 2017
Pamela Leach
Master
Level 3:
Answers
1830
Questions
5
Helped
368493
Points
7356
I would get a new iron. It is eight years old.
5 Related Answers
Anonymous
  • Posted on Oct 17, 2008
SOURCE: shark steam iron
I always purchase your Product and Irons. I like your product very much. so please provide me with address to sent this Iron back for repair. It has always made the lights in the room whenever I Iron go on and off. Also shuts off and on during ironing, then and water leaks from the iron. " Please Help"
Martin
David Shaub
  • 2994 Answers
  • Posted on Feb 12, 2009
SOURCE: Paid $50.00 for Shark model G1405Z. It lasted 3 weeks.
WalMart would have replaced it with or without a receipt for an identical priced product. You can take the bad one back with the receipt and ask for a refund, provided they ARE identical. The barcode is scanned onto the receipt.
Anonymous
  • Posted on Feb 07, 2010
SOURCE: shark iron-61468-10 steam button stuck on dowm
Pull the button up. You may have to coax it up; I pried it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only). Below the button is a stem that operates the valve, gently full it back up with a pair of needle nose pliers (careful - the stem is plastic). Replace the button (align the stem into the hole on the bottom of the button. Cycle the button a few times with water in the reservoir. You should be back in the ironing business now! :) It seems like it sticks when the iron is left unused for a period of time; as if the valve sticks when dry. I'm going to leave water in it this time, although the instruction manual says not to.
Anonymous
  • 104 Answers
  • Posted on Jun 06, 2010
SOURCE: How do I register a Shark Steam Iron on line
Follow the link to register you Shark Steam Iron
https://secure.prodregister.com/euro-pro/hhappliance/yqd_1.shtml
Anonymous
  • 2702 Answers
  • Posted on Jun 20, 2010
SOURCE: shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
Shark iron leaks water from the bottom of the body where the power cord come out. could it be a crack in the holding tank? Is there a way to fix it,or will I need to purchase a new iron?
It is hard to assess what would be the cause, but I think your diagnosis may be correct, of a possible crack, or a tube has come loose. You tube has instructions on how to disassemble and iron if you are up to it and have the tools. Then you'd have to order a replacement part, and re-assemble. I'd just go to walmart & buy a new iron! But that's me! :)
Iron Disassembly Process
Nov 16, 2016 • Irons
1helpful
I have a Shark automatic shut off model G149011 It just shut off and will not come back I have only had the iron for 10 months I purchased at Walmart. How can get the iron fixed or replaced
you prolly have a 1 year warranty, return it to walmart or they will have the address of the local repair depot or contact shark for the local repair depot they use
1helpful
The electrical connection is failing, and the iron is only months old. I really liked this iron and it bothers me that it broke for no reason. I bought the iron at Walmart and no longer have the receipt or...
I would buy the iron at walmart and put the broken one in the box, take it back with your recipt and get your money back.... just like that brand new iron
I purchased a Shark Iron from Walmart in June 2009. It stopped working on Monday, February 1, 2010. Is it still under warranty? And if so, how do I go about getting a new iron or repairs to this one?
Take it back and see...most appliance carry a one year warranty...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Goo on iron sole plate of new iron
let the iron cool completely, use #00 steel wood with dish washer detergent. rise it off with clean water.
Iron quit working in less than 1 year.
Bought my Shark G1400Z iron about a year ago. The iron caught on fire. Luckly I was only out of the room for a few seconds. What can be done about this?
My iron
Trash this iron as the cost of repair would be a lot more than going to walmart and getting one.
3helpful
Shark steam iron
Martin
Top Euro-Pro Irons Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
