You must have a bad thermistor. The program aint getting any signal from it and dont know the temp inside the dryer.
When you call for drying the control checks with the thermistor mounted on the blower housing inside the machine. The reading informs the control the ambient air temp. The dryer kicks in and does another check after a moment to see if everythang is kosher. If it determines dampness then it continues onward till the desired resistance reading indicating the clothes is all dry and she goes into cooldown no heat to allow the clothes to keep from wrinkling. You either have a bad thermistor a bad control or a bad connection between the 2. Look for Dan Webster youtube appliancejunk repair manuals and find your free manual i have in there. Thanks good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: whirpool duet dryer quit working
chould be a fuse inside dryer its oblong white ck it but unplug dryer first
SOURCE: Whirlpool Duet dryer won't move past sensing function on any cycl
Found the culprit. The thermal fuse was blown. Had no conductivity with ohm meter so I placed a jumper around it and presto dryer runs. Cleaned the exhaust and fan but found no blockage and really was not that bad. Hoping maybe just a weak part. The model on the Whirlpool Duet electric dryer is GEW9250PWL I believe the the last three are just the color. The part number on the Thermal Fuse is #3392519. This is easy to get to through the front panel just below the load door. Hope this helps some else out.
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
SOURCE: Whirlpool duet electric dryer timer stopped
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: i have power, the sensing
You need to specify make and model of unit in order to determine the drive assembly. It may be a broken belt, gear, etc. God bless.
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
