Mine has 2 female ends. 3 people 1 of which is an engineer have come to the conclusion that they put 2 female ends on and we can't charge. Plus there are no replacement blades as advertised on the box and it needs batteries for the controller even though it states "batteries included"
Under the cok pit take that of and you will see it reatard
I cant control throtle speed for 7700 skyhawk heli controler does control back roter thow
Yes, take off the cockpit cover and you will find the correct plug to charge.
We had the EXACT same problems with ours! Two female ends on battery and adapter, no blades, no batteries. I tried to call the company, but the voicemail was full so I emailed the problem. Will let you know if they offer any other solution.
In the "cockpit" area there is a lead which will connect to the charger. When you're finished charging the internal battery, disconnect this coupling, and attach it to the lead form beside the motor. Good luck.
How do you connect the charger to the helicopter
