I have the same problem, but isnt when the gas is getting over.
This Revs upo and down are continuous, but when the genset was new that did not happen.The automatic regulation is failing, but where? the electrinic part? the spring in the choke? how to know?
Starving for fuel. the generator will always rev up when it is under a load or about to run out of gas. there will be a few adjustment screws on the carb... one for air and one for fuel. try increasing the fuel a quarter turn and see how that does
SOURCE: honda 2000 eu runs only at half choke once you
These motors have a heat automated choke release system and when it gets hot enough the choke will back off if the ports in the carb are clean and not blocked...if they are blocked clean the carb out real good.
Testimonial: "i will try cleaning out the ports i did suspect this myself i just did not want to tear it down with out a second opinion thank you i will stay in tou"
SOURCE: EU 3000is generator is running rough with Eco Throttle on
The air intake system on this unit is highly fine tuned. Make sure all covers including front battery cover, plenums, air intake system is properly installed and that any and all gaskets on doors and covers are not damaged.
SOURCE: Brand new Honda Generator 2000i
Hi and welcome to FixYa I am Kelly.
Things that must be verified.
1. Fuel selector: ON
2. Start run sw: ON
3. Oil Level : Full
4. Choke selector FULL ON for no more than 2 pulls initially The half choke then off
5. Spark at the Spark Plug YES? NO?
a. No spark suspect low oil level sensor is grounding the ignition either due to low oil level or it just is not working properly.
After doing all of the above...
Spark Plug WET or DRY? Dry and still won't start check fuel supply. If you use the choke with the start run switch in the off position the spark plug should get WET. Spark plug does not get wet... with choke on and ignition off. Fuel supply problem.
At this point I suspect either the Oil Level is incorrect or... that the FUEL SELECTOR is OFF.
If you need more help just respond here and we can press on.
Thanks for choosing FixYa
Kelly
