Bought frig in 2003. I've tried changing the setting for both frig & freezer to 3 or 4 (recommended setting for both) and still my lower two compartments (for fruits/veggies/meat) freeze whatever is in them. I've tried clearing all the vents based on how the air flows. Still have frozen food. Have vacuumed the outside lower vent also. What else should I do?
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
