The freezer handle is loose on one side. How can we take the "door" off to get at the back of the handle to tighten it?
Check to see if your freezer handle has an inlay in the handle or trim that pops off to get at a screw that holds the handle onto the door. If you don't have this then you may have a handle that literally slides up and off. You then tighten the mounting screws or replace the handle if that is what is making it loose. We no longer can tear apart the doors on refrigerators to get at components inside, because the factory puts these together and shoots liquid insulation into the cavity, and this insulation expands and hardens making it impossible to tear doors apart anymore. This is why most handles now are front repairable. Good Luck. Appliance Specialists
Testimonial: "Excellent advice! The picture attached really helped make it clear."
