Kitchenaid side by side... the ice maker is possessed. Will make 1/2 bucket of ice, then will release 1 quart of water which flows into the ice bucket and the rest of the freezer. Do I need a priest, or can I fix this one myself?
It's gonna be either the water valve or the gear shaft in the ice maker. replacement ice maker $130.00 water valve $40.00. gear only comes in with module $90.00. low water pressure from plugged water filter can cause this or if a reverse osmosis system is hooked to it. 40 pounds or more is reccomened for the valve to work properly
The ice
maker not working: ---
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
