I have a maytag side by side, water gets in the bottom of my freezer and will not defrost, it will sometimes run out the bottom of the door.
Oceti right but the drain hose can simply be off too if it off put it back use tie rap to hold it sometime rubber dries up cheers
The defrost drain is frozen. It is located at the back bottom of the freezer. Use a hair dryer to thaw it out and when thawed run hot water through it to check. Afterward, spray some "Pam Cooking Spray" into the drain so the water won't stick. This can be caused by the controls being set too cold or something in the drain line.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
THERE IS NO DRAIN HOLE OR NO DRAIN HOSE VISABLE INSIDE THE FREEZER COMPARTMENT WERE IS THIS HOSE?
