Question about Frigidaire GLTF1670A Front Load Washer
Fabric softener will not dispense
My washer is about 5 years old...about 1 year ago the softener would dispense only partially, but fairly consistently. I have been diligent about cleaning the dispensers, but now the softener will not dispense at all, just collects more water after each wash. One of the reasons that I wanted this washer is for the fabric softener dispenser, otherwise I could live without it...I'm ready to call for repair but thought I'd try here first...any tips on what I can try before calling service? Thanks...
    President:
  • 1,314 Answers
Water remaining in the dispenser is normal doesn't mean its not dispensing consult your owners manuel
Posted on Jan 18, 2008
jetfixr
  • 220 Answers
SOURCE: Fabric softener will not dispense
My wife reported the same problem and I took the top off the washer (2 screws at rear of washer and top slides forward) . Under the top on the left front side behind is the dispenser. On the top is a click adjuster similar to a clock hand pointer and in the center is a tick mark and off to the left side is (-) marks for reduced dispensing and to the right (+) marks for increasing dispensing. I moved the pointer all the way to the plus side and after a few loads the dispenser works fine. I assume over time the different fluids (fabric softener, detergent, etc) tend to gum up the valve mechanism. If this doesn't work I would try pouring some very hot water in it to try and loosen things up. After you try all the free thing, I guess the last option is a new dispenser.
Posted on Dec 28, 2008
Why is my Samsung VRT Steam washer holding water in the detergent/softener dispenser?
the soap, bleach and fabric softner get dispensed by opening a water valve to the dispenser to flush out the items. They then flow to the bottom of the tub. Not all of the water comes out for various reasons, but the important information is that it is seldom critical to performance. If you want to pursue it, check dispenser (take it out) and clean it well. I assume the machine is level.
Oct 20, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Water colects in lid sometime during the cycle.Drains onto washed clothes when lifting the lid to remove clothes. Water seems to be combined with fabric softener. Bleach holder also is filled with water....
I had the exact same problem. The problem is that your fabric softener dispenser is clogged up with a lot of dried, sticky fabric softener. The flooding comes from the part of the cycle when water that is to be flushed through the fabric softener dispenser can't drain properly so it spills into the bleach dispenser and onto the top and into the lid gasket as well.
To remove the dispenser for cleaning, you need to open the top of the washer. (First pull it away from the wall.) Carefully pry off the little emblem in the front center of the washer lid. Then remove the screw. Then slide the top forward to you about a 1/2 inch and prop it up carefully.
You then need to remove both hoses that are attached to the bleach and fabric softener dispenser (part of the same unit). Then unsnap the combined unit from the washer top. Then clean all the gunk out by running it under scalding hot water in the laundry tub and swirling the gunk out. Don't attampt to remove the blue round fabric dispenser part from the unit.
Put it all back together and you're good until you clog it up again with too much fabric softener; maybe several years again.
Good luck.
JRR
Mar 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
I have a basic roper washer thats 3 years old and was wondering if there is a fabric dispenser in it or if all washers have a fabric dispenser u can pour into
if there is no slot either on top or under the lid then there is no dispenser ,not all washers have fabric softener dispenser
Jan 09, 2010 | Washing Machines
I have a Whirlpool Cabrio washer (WTW6400SW). It
try cleaning the dispencer first, it has a small syphon assembly in it whcih can get blocked with concentrated fabric softiner and sometimes powder.
Jul 30, 2009 | Whirlpool WTW6400SW Top Load Washer
Apr 06, 2008 | Frigidaire FWT449
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Bendix Washer/Dryer - softener dispenser not working
the softer dispenser is blocked, remove drawer wash it out with hot water ,clean out small hole in softer compartment close IRE bye
Aug 16, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Frigidaire GLTF1670A Front Load Washer Logo
705 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
