Canon PIXMA MX850 Multifunction Printer Logo
Anonymous Posted on Dec 06, 2009
MX850 - error code 5100 = can you help please.
Canon MX850 - error code 5100 = can you help please. Prints one page then the error codes comes up.
Thanks in advance.
Sue
  • Anonymous Jan 28, 2010
    Thank you - will try this fix.
    Sue
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Jan 28, 2010
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1814394
Points
14613
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Smith William
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Canon Expert 241 Answers
  • Posted on Sep 12, 2019
Smith William
Canon Expert
Level 2:
Legend:
Answers
241
Questions
0
Helped
324470
Points
856
Canon printer is one of the best brands in the world many big organisation are relying on the canon printer, its unmatched printing quality and versatility makes it more best printing devices in the world, but every machinery devices causes problem, but don't worry we have a proper solution, Kindly visit us to get the proper solution
How We Support:
100% Fully Assistance
We Are Available 24*7
We Work Fast as per Customer demand
For More Info Do Visit Us: canon printers error code 5100
Toll-Free No: +1-888-633-7151
303 Electronics
Level 3:
  • Canon Master 370 Answers
  • Posted on Feb 25, 2019
303 Electronics
Canon Master
Level 3:
Answers
370
Questions
0
Helped
404651
Points
2643
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1931
Points
I can verify that cleaning the timing strip works.
I was getting a 5100 half-way through a printed sheet. I used isopropyl alcohol from the drug store (70%), and cleaned both sides of the timing strip (**** strip) with a Q-tip. Made sure to clean *both* side of the st
A symptom of a dirty timing strip is that there will be vertical gaps visible in test output when you print the nozzle checksheet, and this gap appears in all of the colors. The gap will be slightly off in position from color to color, but this is because the nozzles for each color are in slightly different positions relative to each other.
If you simply look at where the gap is in the black output on the nozzle checksheet - that is where the dirt is located on the timing strip.
Sure enough, when I shined a light in there - I could actually see the smudge on the timing strip.
Thanks to this thread for giving me the clues I needed to avoid an expensive repair job!
2answers
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
What is the Canon MX850 Error Code 5110?
The paper goes in from the front, under the 'paper output' tray.
My printer keeps coming up with error code 5100 what does this mean ? thanks Sheryl
a possible solution is to download a registry scan tool. go to 'scan registry' then click 'repair' hope this may help
2helpful
Error code 5100 on my canon mx850 How do I clear this?
Hi Hope this help you
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Techbelkin
6helpful
I got an Error Code 5100 in my Canon Pixma MX850, but it is because a paper got stuck under the print cartridges.
error 5100 is a carriage error, meaning the printer cannot find the position of the carrier. You have likely gotten some grease or ink on the 10mm wide plastic strip that goes through the carrier, just to the rear of the ink tanks. Unplug the printer with the cover open, then you can manually move the carrier from side to side and use a tissue to wipe any material from the encoder strip.
1helpful
Error code 5100 comes up. Says to close and restart printer. I do this and it prints fine for a few pages, then error code comes up again
Opem cartridge door
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions on carriage path (iron rode). Please see blow video to locate "carrage"
http://www.youtube.com/watch?v=l9x6ZLIYMog
Thanks,
Viju
1helpful
What does error code 5100 mean?
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
MX850 ERROR CODE 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Error code 5100
Hi You can Try
Error Code 5100 It the most errors that on canon
Solution 1:
Solution 2:
old marine
old marine
ZJ Limited
ZJ Limited
