D you mean battery drain, not gain? Possible other causes are: Maybe you got an old battery put in, this does happen sometimes. Or, maybe the lubricants have dried out causing the gears to get sticky/gummy and causing excessive battery drain. I use an instrument than spin the movement and loosen up sticky gears after using a spray cleaner.
I had the battery checked and its good. I have tried hand spinning the minute hand and it seems to help for a little while. Its only been about 9 months since I bought it. I may need to try the spray Idea because now it stops after a few minutes. What type of spray do you use and how could I spin it faster?
