NORMALY THE HOT FLOW ENTERS THE TOP HOSE AND COOLER WATER LEAVE THE BOTTOM HOSE BACK TO THE BLOCK, SO IF THE TOP HOSE GETS WARM THEN THE RAD IS BLOCKED , IF NIETHER GETS WARM/HOT THEN THERMOSTAT NOT WORKING, OR YOU HAVE BLOCKAGE ELSE WHERE, SO REMOVE BOTH HOSES FLUSH RAD WITH HOSE PIPE, (WHEN ENGINE IS COLD) SEE IF WATER FLOWS OUT AT SAME SPEED AS U R FILLING IT, IF NOT ITS BLOCKED, 2ND REMOVE THERMOSTAT AND FLUSH ENGINE OUT, U CAN BUY RAD FLUSH/CLEANER AND TRY THAT,
Testimonial: "I HAVE HAD A NEW RADIATOR FITTED AS WELL. The top hose does get hot and the bottom hose warm so this could be normal. Thanks for the advice"
