Remove the drain pump and check out.
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
its the problem in the pump and something is getting blocked in the pump so water is not getting out.
Front-Loading Whirlpool Washers
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
It's not the drawer that is the problem. It is the basin that the drawer slides into. The water begins to go down the drain tube into the drum, but doesn't drain in that tube fast enough and begins to back up into that basin. The problem appears to be from the drain tube into the drum. The drum spins OK too.
