It is possible that the phone needs a reset to default settings. So open,menu> settings> restore factory settings and type 12345.Also remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone.
The phone must reset to the default settings.
Thank You for using Fixya
Using a memory card
You can save, move and delete the files
between your phone and external memory
card. You can also move and copy the files
to computer from your phone.
To copy a file to the memory card
1. Select the file > Options > Copy to
External Memory.
2. To copy the file back to the phone, press
Options > Copy to Phone.
To move a file to the memory card
1. Select the file > Options > Move to
External Memory.
2. To move the file back to the phone,
press Options > Move to Phone.
To delete a file from the memory card
1. Select the file from the card > Options
> Delete.
In Advanced Mode, you have access to all
of the features of Breeze II including the
features provided by Breeze Mode.
To move the file from the card to the
computer
1. Connect the data cable with mobile and
the computer.
2. Press Menu > Settings >
Connectivity.
3. Press Select USB Mode.
4. Select Music Player, Mass Storage or
Ask on Connection.
5. Follow the instructions on your
computer screen.
note: Select Music Player when you want to
add music to the playlist in your device. When
you select Ask on Connection, it will ask you to
select either the Music Player or Mass Storage
every time you connect your device with your
computer.
Resetting a memory card
1. Press Menu > Settings > Reset.
2. Enter the password > External
Memory Reset.
note: The default password is '1234'.
