Hi, BRIANMICHELL ? How much oil are we talking about, and over what period? How old is your machine? Your KA mixer?s internal gears are factory packed with enough grease to last a lifetime, whatever that means. Depending on the age of your mixer, where it was stored (warm temps possibly?) and how long it's been idle and/or how heavily it?s been used; these factors all will eventually cause the lubricant grease to separate into its base oil from its additives, with the resultant oil seeping from openings beyond the gasket down the agitator shaft. Gravity can be very insidious. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try KSM150PS, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 6 & 7, titled ?Case, Gearing and Planetary Unit?, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. For starters you may want to order parts #15, transmission gasket, and # 16, O-ring, along with some food-grade grease. Also, while you?re inside the guts of your mixer you can check for any other unseemly wear and tear on the gears, etc. It can be messy but gratifying. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html Good luck and have fun. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
After seeing this information we put Harley-Davidson decals on it and found a nice drip pan to put the mixer in so it doesn't leave the oil slick on the counter top. This works great and it is actually a great conversation piece for parties as it really leaves a nice sized spot of oil in the tray just like my old 1975 Harley Shovelhead. Kitchenaid is really missing a marketing move here!
