My Brown Gas Stove with oven would not stop flickering after you turn the oven on it stops then continue to flicker like you are turning on the ignition
I need help email [email protected]
This is usually due to the "brain" of the stove going bad, better known as the control module... not an expensive fix if you can find the part and due it yourself... you can locate it iether in the back right corner when you lift the stove top or it's under an access panel below your broiler drawer depending on model.
