Emerson EWL3706 37 in. LCD Television Logo
Posted on Nov 29, 2009
My mom has an Emerson LCD Color Flat Screen TV Model #: LC320EM8. When you turn the TV on, it has thin red, green, blue, yellow and black lines running from the top to the bottom of the screen. What would be causing this problem?
  • Anonymous Mar 19, 2014
    tv has green lines and green patches.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 18, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1513
Points
The colors red, blue, green, gray are rolling (changing on there own)
Anonymous
Level 1:
New Friend:
  • Posted on Jan 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1513
Points
COLORS OF LCD SCREEN HAS TURNED TO PINK AND PURPLE WHAT TO DO NOW?
When trhing to watch Netflix I get an error message"this content requires HDCP for playback" on my LC320EMX
HDCP- High bandwith digital content protection is something that would be built into your tv. it prevents you from copying programs to another device. You have two options- one use a different type of cables like say rca red-white-yellow cables or for hd video. component blue green red cables and red and white cables for sound
7helpful
I fell asleep on my Emerson LC320EMX 32 hdtv remote; when I awoke, the tv was flashing ONLY colors (red, black,blue,white)...Now, How do I get it out of that mode....I was told its stuck in set-mode ?
I had this problem with the LC320EMX, after extensive searching on the internet, I found a solution. The TV has entered some kind of test pattern, to escape from the flashing color test pattern do the following:
While the screen is changing from red,green,Blue,White, & Black, and is Unresposive, Take your factory remote, Press the up arrow, then the down arrow, then (ON THE TV) press the power button. Turn the set back on and it should be functioning properly. (BTW: the set gets into this test pattern if you press too many buttons on the remote, or if you use a universal remote with the wrong code)
2answers
Black vertical lines lc320 emerson
I'm sorry but this is a symptom of an internal problem. You will need to reference a TV repairman.
12helpful
I have a 32" emerson and start to change color the full screen green red white and you cant turn off , is just changing color i want know if wer out or what?
with your remote hit the arrow up and them down arrow it should then say turn power off if not you may have to repeat the proceedure and include
left to righ then turn unit off you should be alset
Emerson tv dont work with xbox. can only hear audio but no video
IS THE THING PLUGGED IN RIGHT? YELLOW TO THE YELLOW, RED TO THE RED, WHITE TO THE WHITE? HOW ABOUT GREEN TO GREEN, BLUE TO BLUE, RED TO RED, WHITE TO WHITE?
7helpful
I have a LCD Color TV, but when turn on, green
The most common problem is the Power/Backlight Inverter Board. There are 6 mini transformers on the board, one goes bad and the TV will turn itself OFF automatically for " Protection Mode". Replace the whole board or replace the bad mini transformer.
Part number#
Whole board, BA71F0F01042
Mini Transformer, LTZ2PC0MS008
Trying to hook playstation 3 and tv says format not supported
hook up ps3 with green blue and red jacks componet use red and white for audio
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
