My MW511 model is not spinning , slow motion wash cycles, noisy
My MW511 model is not spinning although the water is running fine through it, the wash cycle is runnung rather slow and it makes a loud noise on rinse. please help
most likely the water valve is faulty. The inlet water valve is at the end of the fill hoses. trace your way to it and get a new one and replace it. Before you do check the inlet filter is not blocked. good luck
Hi, check leveling of machine, machine should be proper leveled on all side, use spirit level to adjust legs, there should be no rocking motion, in any direction after leveling, put hands on top of machine and try to rock it sids to side, there should be no movements, also check for overloading, be careful when washing things like bath towels, etc, they absorb lots of water, eg. one regular bath towel are equivalent, to six pants, six tops. or possible springs or bushings broken, you need open machine and check.
Several items can cause no spin or slow spin. I'm assuming the motor runs during spin and the water all drains out. A worn or damaged belt can cause your problem. Always replace the drive belt and pump belt at the same time.
Check for smooth and non binding motion of the motor in it's carriage.
A failing bearing (either tub bearing or spin bearing) will restrict tub motion in spin.
A garment in between the inner and outer tub will also restrict tub spin performance.
washer making a load cluck noise when the spin cycle starts. It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine. if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Having the same problem. Any ideas at all? It's really frustrating.
nwesthamz Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops
filling nothing happens. However sometimes it will go complete cycle
ans a noise can be heard on spin cycle even though it is not spinning.
As thoiugh the motor is not engaging with the cylinder Was this helpful?
Yes
No
