Kingston 4GB Secure Digital High Capacity Memory Card Logo
Anonymous Posted on Nov 28, 2009
How do i go about formatting my kingston sd card, step-by-step?
  • 1 more comment
  • Anonymous Nov 29, 2009
    A LG Rumor 265
  • Anonymous May 11, 2010
    In what device are you using your SDHC card? Are you sure the device supports SDHC media? If not, you will get a generic error explaining that your card is not recognized, and to reformat the card. (Reformatting may not be necessary of course if media is not compatible).
  • Jitendra Sen
    Jitendra Sen Aug 28, 2016
    my formet card volume lable told me please
Anonymous
Level 3:
  • Master 557 Answers
  • Posted on Nov 28, 2009
Anonymous
Master
Level 3:
Answers
557
Questions
Helped
196710
Points
1635
Insert card into card reader. Find which drive letter the card is in. Right click on that drive. You will see an option that says format. A warning will tell you anything on the drive will be errased. Once sure you have the right drive click OK.
Testimonial: "VERY VERY HELPFUL!!!THANX!!!"
A
Anonymous
Hello...Pal! you have two options to format for micro sd card. One is, you are to open my computer and right click on the sd card drive and choose format option. This will display a window, there is a option of quick format, make a check sign to this and press format button. Second is, go to start menu -> Program Files -> Accessories -> and choose command prompt. when command prompt window opens, type e.g, "format K:" and press enter, if it ask for volume label, type its drive name like Personal (C:), only type the name e.g, Personal, and if it does not ask for volume label, press enter one more time, then this will show a surity message, type Y and press enter, your micro-sd card will be format successfully.
Testimonial: "THANX!!"
Mihaila Marius Adrian
Level 1:
Habit-Forming:
New Friend:
  • Contributor 22 Answers
  • Posted on Nov 11, 2016
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
22
Questions
0
Helped
3127
Points
63
To reset this SD card , enter it into a device connects to your PC with a data cable then in my computer you will find the memory card a must give the right-click properties>>format.
4 Related Answers
Anonymous
  • Posted on Nov 14, 2008
SOURCE: how to unlock my kingston sd memory card
i forgot password plese tell how to unlock
Rakesh Kumar Jangra
  • 88 Answers
  • Posted on Apr 06, 2009
SOURCE: Cannot read Kingston 2GB SD card on my computer
Dear,
All just try this trick
Connect your phone to PC and try to acces the card on PC. Now format the card but, take the backup of data before formatting the card.
Regards,
Rakesh Kumar
Anonymous
  • Posted on Aug 28, 2010
SOURCE: how can i format my locked micro sd
my memory card wants password but i did not create password in my memory card.so my memory card is locked.how can i solve this problem?
Anonymous
  • Posted on Oct 21, 2010
SOURCE: My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
2answers
My pictures on my microsd card were corrupted
Its most likely your Micro SD card thats faulty. If its a Sandisk of Kingston then theres a 12 Month warranty on them but if its one of those cheap no name ones they are a complete joke and will continue to corrupt everything put on them. Invest in a good brand one.
Plz, how do I remove a write protection error from micro SD disk, it was just purchased and I am getting this error msg, this is the second one I am buying with same issue. It is a kingston brand (if that...
Try the following: 1. Click Start > type "regedit" and open "Registry Editor". 2. Now follow the below path after opening registry editor :- HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/StorageDevicePolicies. 3. Now you will see "Write Protection" option. Double click on that and set the value data to '0'. After setting the value data to '0' again try copying or formatting your sd card. After performing the above step you are still not able to format your sd card then continue to next step. Open Command Prompt and type diskpart and press Enter key. After opening diskpart type "list disk" and again press Enter button. Now type "select disk 1".
2helpful
Windows media player 11 dectets kingston 4G SD memeory card but will not allow to format it
To format the memory card you need to go to my computer,right click on the memory card icon and choose format that will format the memory card.
5helpful
2answers
How can you format a SD 4gb card for the Kodak EasyShare Z612 Digi Camera
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
11helpful
3answers
I cant remove the write protection of my kingston
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Can't format my kingston micro sd memory card
you may do not have administrative rights to format [or it may be password protected]
Micro sd card deleting problem
Dear,
You need not to think about that because such amount of space used by the Drive for its file system.
Regards,
Rakesh Kumar
Not able to copy more than 1GB into 2GB Kingston SD card
Hi 1123sun,
Copy your files off the card. Then Format the card and select FAT32 file system. After the format is done try the card again and see if you can copy more files to it.
Kingston Tech Support
3helpful
2answers
Dear,
Regards,
Rakesh Kumar
4helpful
4answers
How to format the microSD?
actually u shold format it by the device in which u are going to use. eg camera. This will enable correct formating for usage of this device.
otherwise their is a standard Sd format and u can use that to format
You can format the card by SD card Utility. SD utility is a format utility which is release from SD Association. It is a standard for all SD type card and will self determine the SD card's file system. Please kindly refer to the link below for SD format utility download webpage.
http://www.sdcard.org/about/downloads/
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
