Found water on the floor in front of the washer. When I pulled machine away from the wall, I found water underneath ir but no leak from input or output hose. Could this machine be leaking from the center???
Thank you.
Rose Marie
Purchased a Kenmore HE 2T a few months ago. We discovered water on the washer during the rinse cycle of 1 large load of wash. A Sears repairman checked over the washer and told us we were using too much HE detergent and this caused water to leak out from the door. He said its a common problem with front loaders and recommended using 1/2 to 1/4 (if a water softener is installed) the amount recommended by the manufacturer.
We use the washer everyday and so far no more water leaks.
Check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Water comes from underneath in front of washer
