Question about LG 27LC2R 27 in. LCD TV
LG tv shows av inputs as black & white
I have an LG lcd tv model no 27lc2r. It's showing av inputs in black and white but hdmi works fine. I have read about doing a restore factory defaults by pressing the menu key for 5 seconds and entering a digit password. Does anyone know the password please?
Many Thanks
Lee
  • 834 Answers
You need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
Posted on Nov 28, 2009
Suddenly, all three HDMI Ports won't receive a signal. Help!
Hi James,
The main board of your TV is not accepting HDMI input. You can use another AV input to watch the TV or you have to change the main board.
Aug 04, 2015 | LG 42LG30 42 in. LCD HDTV
I have a problem with my samsung lcd it shows me black and white screen i try to set it with manual shows component -pc instead of av -tv
Looks like you need to reread the manual & properly connect. you are plugged into the PC & not the AV input & this is most likely your issue.
Dec 31, 2014 | Samsung LN-26B450 26 inch Series 4 LCD...
Guys, Recently i got LG 22" LCD TV. It has VGA port and HDMI port. When i connected my CPU cable toLCD via VGA port it didn't show anything, :"( i checked input MENU on remote then it shows only 4...
HDMI [High Definition Multimedia Interface]. VGA [Video Graphics Array]. AV [Audio Video]. By these definitions itself talk to you about the inputs your TV have; and it do not support VGA. Output from PC is VGA. Without a VGA input with the TV, you can't connect the PC to TV. I think I'm clear. http://electronicshelponline.blogspot.com/
Jul 09, 2014 | Televison & Video
Connect tv to iPad NO SIGNAL problem
Check the input or source on the TV to make sure it is on the correct input for the ipad.....
Apr 30, 2014 | LG 19LS4R 19" MULTISYSTEM LCD TV...
Lg tv guide
For more details, check its user manual.
May 22, 2013 | LG 32LD350 32 in. LCD TV
Hdmi wont connect to hdmi on laptop - shows lg screen on laptop with no model number but shows no signal on tv
Hi andy838,
I see that you LG LCD HDTV is giving you a No Signal message on the Screen.
see steps Below on finding out what will show video on your LCD HDTV.
* First make sure that the HDMI cable is connected to your Laptop to the HDTV LG.
* On your TV check your remote control and look for the input or Source Button, this will help you set your TV for the HDMI connection.
* Once set, turn your Laptop on and see if the HDTV will provide Video from the Laptop to your HDTV using HDMI.
* I believe that works right, now we have video still we need to set the Audio to work from you Laptop using HDMI to your HDTV.
* On your Laptop lower right side look for your speaker icon, right click on the speaker icon then select Playback Devices.
* Once you've selected Playback Devices you will see a window showing you a list of devices and the first one on the list will be you HDMI connection right click on it and select set as default device this will make your audio work on your HDMI to your TV.
* Once audio to HDMI is set and you want to go back to your Laptop just set the speakers as the default device this will set your speakers have the Audio working again on the Laptop.
I hope that this will help you regarding your concern.
Have a nice day,
mvincentc
Feb 25, 2011 | LG 42LC2D 42 in. LCD HDTV
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
LG 27LC2R 27 in. LCD TV Logo
946 people viewed this question
Ekse
RONALD CARTER JR
