Seeing double when I look with both eyes.
I think you probably know how to focus and that they need alignment, have repaired many and not the type of thing to do yourself...if i can help further [email protected]
Step 1.
Adjust the eyepiece or both if both are adjustable back to zero. It should be printed on there. If it's not, then halfway. To find halfway turn them to one end, count the number of turns like 1 and a half turns for example, and then half that atnd turn it that ammount. You've now reset the binoculars to zero.
Step 2.
Now to focus. Pick your target that you want to look at thoguh your binoculars. Look through the binoculars and close the eye with the adjustable eyepiece or your right eye if both are eadjustable and focus the image on the left eye with the central focus knob. Once you've got it focused close the left eye, open the right eye and if it's not in focus adjust the EYEPIECE focus, not the central one, until it's in focus.
If you can't get it in focus because the eyepiece focus won't turn far enough in one direction, turn the OTHER eyepiece in the opposite direction at max, start the process again from step 2.
If it's all ok now you need to adjust the distance between the eyepieces. Open the binoculars as far as they go, look through the binoculars with both eyes on the target and move the binoculars inward slowly until you remove any black edges around the image, then move them very slowly inward until you see only one image.
If you've got more problems come back as ask. :-)
