The replacement part number is WR30X10093 it is GE's newest electronic icemaker,all newer style icemakers and designed to also work for older models such as yours
ICEMAKER BROKE AND I NEED A NEW ICE MAKER. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
Might should check the condenser fan in the rear of freezer section. sounds as if it isn't running at its peak performance. May just need replacing. BB
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
I have not heard of this issue but if it is coming from the icemaker, then it will have to be replaced. You are still under warranty so call to have them replace it now, otherwise the new icemaker will cost you about $125.
GE uses an electronic icemaker that is not field serviceable. if the Icemaker is getting water then something in the icemaker has failed and the complete icemaker must be replaced. the part number is wr60x10093 I believe and can be purchased online and many different places or thru local appliance parts supply house. thanks peyton
Blinking light indicates a fault with the icemaker. Look for a blockage preventing the ejector from making a complete revolution, such as a cube that was not cleared, or some other mechanical blockage. All other faults are icemaker component, which are not available as separate repair parts, which would require replacement of the entire icemaker assembly. Please don't rate this if you need a new icemaker, as anything less than a Fix-Ya lowers my score. Thanks.
YOU CAN PULL THE FRONT COVER OFF TO SEE IF THE GEAR WHEEL IS BROKE,OTHER THEM AT CALL YOUR LOCAL APPLIANCE PARTS STORE AND YOU CAN GET A NEW ONE FOR AROUND $70,THANKS-MIKE
