Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
Posted on Jan 14, 2008
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I have a Sub-Zero 550 and water is dripping onto the freezer draw and freezing making it hard to open the freezer. It seems like water is leaking out of the tray. How do I fix? How do I get to the tray and drain line to see if it is plugged up?
  • 7 more comments
  • UpdateDude Jan 27, 2008
    I'm having the same problem.
  • seanfarrell Feb 02, 2008
    I'm having the same problem too! Definitely interested in any fix you may find.
  • stevecoppage Feb 03, 2008
    I also have the same problem with my 550.
  • MarkEriksson Mar 09, 2008
    I have a 550 and have the same problem as the other people. I've had mine for 5 years without any problems except a door hinge. My freezer drawer freezes closed when not opened in 12 hours. Has anyone lese found out what the fix is?
  • arizjack Aug 29, 2008
    I have the same problem with both freezer and refrigerator. Could you please tell me where I can purchase the heater kit for a model 550?
  • aundy Oct 03, 2008
    I called an appliance company who said to install a Sub Zero heater kit that will stabilize the temperature at the bottom of the fridge where it meets the drawer freezer below. They want to charge me $550, which seems very high. Does anyone know if this is a reasonable price?
  • WhislerD Mar 25, 2009
    Sub-Zero 550 drain trough spills-over into the inside of the refridgerator compartment, eventually leaking out the door seal an onto the floor. Technician said the drain tube freezes because of the close proxcimity to thefreezer compartment. He said to defrost the freezer completly to clear the drain tube.
  • wags2099 Mar 31, 2009
    I have a 550 model with similar problems.  We have spent a lot of money to fix it, including the heater kit that is mentioned in several of the answers.  These repairs alone have totaled over $1000.  To be honest, I would not spend the money again and would probably buy another (non sub zero) refrigerator.  The unit is about 13 years old now.  We have had to turn off the ice maker which also had problems.  In contrast, the refrigerator it replaced, a GE that is now 21 years old is still in the basement working and has never needed a repair.  It seems ridiculous that the company acknowledges that these problems are typical for this model.
  • Anonymous May 11, 2010
    The Ice Maker (Tray) ??
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7988
Points
5
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
DOUG DYKAAR
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Oct 21, 2008
DOUG DYKAAR
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
10882
Points
12
My Subzero 550 did this: The right side of the freezer has a drain that was plugged with ice. When the freezer defrosts the water runs down the inside of the box and onto the drawer rails, where it then freezes. The drain tube is normally kept ice free by an aluminum strap wrapped around the copper defrost tube in the freezer heat exchanger, which runs down into the drain tube. Over time the copper defrost tube gets some surface corrosion and the aluminum strap doesn't get warm enough during the defrost cycle to melt ice in the tube. If you can get it apart, you can clean up the tube surface with steel wool, or buy the electric defroster for the drain tube to replace the aluminum strap.
Anonymous
Level 1:
  • Contributor 26 Answers
  • Posted on Mar 31, 2008
Anonymous
Contributor
Level 1:
Answers
26
Questions
0
Helped
23130
Points
77
Sounds like your freezer drain is blocked up. You will require a freezer drain heater kit for this repair. It was a common problem for this unit and can be a easy fix. However it does take some patience to fish the heater down into the drain pan.
  • dottielove46 Nov 26, 2013
    My fridge leaks on floor on right side every morning, but there is no ice noticeable anywhere. I've taken the back panel out of the freezer side looking for a drain hole, per suggestions, but couldn't find one. Anyone have a schematic? That would be very helpful.
Anonymous
Level 1:
  • Posted on Jun 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7988
Points
We have had a chronic problem with bottom of fridge getting wet/water puddles and leaks onto floor. when this happens, there is inevitably a lot of ice buildup on the bottom of the fridge, near the drain tube and the drain tube is usually frozen. i read many posts re: this problem and various fixes, and tried some (never spending any money), but have mostly just cleared the ice from the bottom of the fridge and put hot (boiling) water into the drain tube (which I disconnect) with a turkey baster until cleared. However, I did notice, recently, that there is water leaking down from the trough which is supposed to take the condensate into the drain tube and I have a new theory -- the seal at the back of the trough leaks, allowing water to hit the refrigerator floor and freeze. When the ice builds up to enough height, it contacts the drain tube and the draing water freezes, which then allows all condensate to spill over onto fridge floor and out onto kitchen floor. SOOOO, what I did was loosen the back trough screws (about 8 of them) and found that there is a white silicone seal strip which lifted right out (i.e., no longer adhered), which leads me to believe that it had just loosened over the years and was no longer sealing. I then put clear silicone seal into the gap with my finger and tightened the screws. I will now watch to see if this helps, but the hope is that the spillage onto the kitchen floor was due to ice buildup in fridge and the frozen drain tube also caused by the ice buildup in the fridge. Hopefully, by sealing the trough to the back fridge wall we have solved the problem? It sure was a lot cheaper than a $500 heater in a fridge.
  • Anonymous Oct 30, 2011
    Did This work?
  • Anonymous Sep 18, 2012
    Yes, I'm curious too. Did it work?
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
9helpful
3answers
My Sub-Zero drain ices up too!
There is a drain tube heater and a floor pan heater kit for this model from Subzero
This is Not for a DIY project
Affordable Appliance Repair
Lake Forest, CA.92630
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
4helpful
The drain line has been clogged. There is actually a defrost heater kit for that problem if you can get the obstruction out. Did you call factory at 800-222-7820 or a local factory authorized servicer? The drain is accessed by removing the fan shroud and evaporator cover. There are a number of of phillips head screws that hold this in place. Once you have removed the two cover you will see the drain tube on the left side of the unit. I use a hair dryer to start defrosting the tube. If you have another freezer in the house it is easier just to turn the freeezer section off for a day or so. I use nitrogen to blow the line out from the bottom once everything has defrosted. Test for water flow, then put unit back together. Call the factory at the number above for the heater kit part number and they will also give you the local authorized parts supplier. The locator web address is http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 • Freezers
Subzero 550 Gurgling whenever door closes
Personally it does not bother me that much on mine. But since you asked, there is drain line that runs into the drip tray underneath. The line should not have any bends in it to form a P-trap which will hold enough water in to form a seal, so when the door closes and the pressures equal you have a gurgling sound. If it really bothers youtry these steps, remove the kick plate by removing the two phillips head screws on either side. The drip pan is suspended in the middle of the support and will probably have water in the drip pan so put a towel down before you start. Once off shine a light to see if the tube has a bend in it. Depending on when it was made there may be a clamp that hold the drain tube in place. Carefully pull the hose past that clamp to remove sag and eliminate the bend which forms the P-trap. You have to be careful as the hose maybe brittle and come apart. So if you pull to hard you may wind up replacing that line which requires pulling the unit at considerable cost. There is a check valve that can be ordered but was only used for a short time. The inline check valve was a part number 4202130. If it bothers you too much and don't want to try the fix here is the Sub Zero locator page for parts and service. http://www.subzero.com/locator/locator.aspx?type=0&zip=02030
550 Sub zero
your drain is clogged or frozen over,the drain is most all the time in the middle back bottom of freezer,you might have to remove the freezer back wall to get at the drain,use a hair dryer to melt the ice and a metal hanger to clear the drain,let me know how you make out-mike
Sub Zero 550 series... The freezer door gets stuck and won't open. There's frozen condensation leaking.
The right side of the freezer has a drain that is plugged with ice. When the freezer defrosts the water runs down the inside of the box and onto the drawer rails, where it then freezes. The drain tube is normally kept ice free by an aluminum strap wrapped around the copper defrost tube in the freezer heat exchanger, which runs down into the drain tube. Over time the copper defrost tube gets some surface corrosion and the aluminum strap doesn't get warm enough during the defrost cycle to melt ice in the tube. If you can get it apart, you can clean up the tub surface with steel wool, or buy the electric defroster for the drain tube to replace the aluminum strap.
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
4helpful
Ice in Refrigerator Section
there are 2 possibilities. first the drain is blocked causing water to overflow from the defrost water gulley at the bottom rear of the inside of the fridge. this can form ice as it is close to the division between fridge and freezer. second, the .fault of ice growth can be caused by breakdown of the cabinet insulation. of the two, the first is the moree likely. to test drain is cloear, pour a little water down the drain. if it does'nt flow freely, push something flexible down the drain hole till blockage is clear
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
