Need owner's manual for LG 42" plasma modle number 42pq30, but the file on the lg wesite wont download,and I can't find a free one anywhere else, help!
You must use a usb memory stick to copy data values from the old board to the new board. First you have to put the old board back in, insert the stick then follow prompts to copy register values to the memory stick. Then put the new one back in and load the values back onto the new. I would definitely have a certified tech do this process. You don't want to make a mistake with the old board values.
you need the set up remote, part number 105-301-m . in start mode press tools button, rt click until your model shows up. the main board is for several size screens. HIT enter when you see your model number.
Please post feedback
yes is the 2 top & botton board connect to Y board control is bad need new one
Most problem on plasma TV is heat & burner some component, about 80% is 2 top & bottom board connect to Y board is come in bad
I HAD THE EXACT SAME ISSUE ON MY LG TV. WENT THROUGH EVERY PROCESS REMOVE BATTERIES, UNPLUG ETHERNET CABLE, HOLD IN POWER BUTTON ETC ONLY TO FOND OUT IT WAS MY FIRESTICK REMOTE THAT WAS THE PROBLEM. THATS WHAT WAS TURNING TGE VOLUME UP TO 100. I CHANGED THE BATTERIES AND CLEANED THE BUTTONS AND TURNED IT DOWN. PROBLEM HAS NOW GONE.
well, if the cable and adapters are friendly (meaning, you are able to plug the right video connection from LT to TV), sometimes you need to tell you LT that you have a second screen to output video. To do that, there should be a display icon in your bottom-right taskbar. Double click, and you should be able to see the options to either clone, pan, or primary your second display screen. :D
Your set should be under warranty. This could be a clocking circuit that is out of sync, or some other processing device that is out of frame sync. To service this at board level, if it is not a standard factory known fault to correct, or if it involves extensive SMD work, the board with the fault will be replaced.
press intreactive on sky remote move down to sky costomer service press select then move down to program remote ( 5 ) you will need make ( lg ) and model number of tv then follow on screen instructions
hope this helps
