Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Posted on Nov 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Print head needs a good cleaning,deep cleaning just won't do it. jrc
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
528
Points
Anonymous
Level 2:
  • Expert 295 Answers
  • Posted on Nov 28, 2009
Anonymous
Expert
Level 2:
Answers
295
Questions
Helped
108784
Points
501
You do not have 2 do the cleaning of printhead often ..Printer has a self maintenance process which automatically clean the printhead also.Yeah,u do not have to take the printhead out and clean it with a cloth or alcohol as it can damage the printhead as well as printer.
When I go to print everything looks good. The paper feeds through the printer but nothing prints on it.
Welcome to FixYa.
This problem might be due to blockages in the print head nozzles or if a FINE Cartridge is empty.
Kindly try the print head cleaning function to remove any blockages in the print head nozzles.
The procedure for cleaning the print heads, in the printer driver setup window (The printer driver setup window can be displayed through the application software in use or the Start menu of the Windows), is as follows:
Cleaning:
1. Make sure that the printer is on and click Cleaning on the Maintenance tab.
Print head cleaning starts.
2. Click OK when the confirmation message appears.
3. Next, the Nozzle Check dialog box opens.
To check whether the print quality has improved, click Print Check Pattern. To cancel the check process, click Cancel.
If cleaning the head once does not resolve the problem, clean it once more.
Deep Cleaning:
Deep Cleaning is more thorough than Cleaning. Perform deep cleaning when two cleaning attempts do not resolve the print head problem.
1. On the Maintenance tab, click Deep Cleaning.
The Deep Cleaning dialog box opens. Follow the instruction shown in the dialog box.
Click Initial Check Items to display the items you need to check before performing Deep Cleaning.
2. Make sure that the printer is on and then click Execute.
Print head deep cleaning starts.
If there is still no sign of improvement, the ink may have run out and the cartridges need to be replaced.
For more details, please download and install the complete on-screen manual from this link.
Thanks for using FixYa.
1helpful
My printer is skipping lines. do I need to clean something?
1. Make sure that the machine is turned on, open the Paper Output Tray, and extend the Output Tray Extension.
2. Load a sheet of A4 or Letter-sized plain paper in the Cassette.
4. Start Print Head Deep Cleaning.
(1) Press the Menu button.
(2) Press the or button to select Settings, then press the OK button.
The Settings screen is displayed.
(3) Press the or button to select Maintenance, then press the OK button.
The Maintenance screen is displayed.
(4) Press the or button to select Deep cleaning and then press the OK button.
The confirmation screen is displayed.
(5) Press the or button to select Yes and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep Cleaning finishes. This takes about 1 minute 30 seconds.
5. Check the condition of the Print Head.
(1) Print the nozzle check pattern to check the print head condition.
(2) If the print head nozzles are still not clean, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
3answers
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
My MP530 willnot print black printed text. How do I now if the ink head is plugged and what do I do about it?
Hi ...
I would suggest you try and clean the print head and that should resolve the problem. Follow the below steps to clean the print head:
Perform a Cleaning of the print head:
Caution: Cleaning consumes a certain amount of ink. Perform Cleaning only when necessary.
Note: The pattern varies depending on the printer and version of Windows being used.
  1. Click 'Cleaning' to perform print head cleaning from the Pattern Check window and proceed to step 3 of the print head cleaning instructions. If the Pattern Check window is closed, skip this step and proceed to step 2.
  2. To perform a print head cleaning from the Maintenance window, click 'Cleaning'.
  3. When the Print Head Cleaning window is displayed, select the target ink group for 'Cleaning'.
    Note: When performing Cleaning for all colors, check 'All Colors'.
    Note: When performing Cleaning for Black only, deselect 'All Colors' and check 'Black'.
    Note: When performing Cleaning for Color only, deselect 'All Colors', and check 'Color'.
  4. After selecting the target ink group click 'Execute' to perform the cleaning of the print head nozzles.
  5. When the confirming message is displayed, check the contents, and click 'OK'.
    Caution: Although the Nozzle Check window is displayed, do not perform any other operations until Cleaning is completed.. Cleaning will take about 40 seconds.
  6. Print a Nozzle Check Pattern and examine.
  7. Perform Cleaning again if necessary.
    Memo: If the pattern is still abnormal after two Cleanings, perform up to two Deep Cleanings.
Perform Deep Cleaning of the print head
Caution: Deep Cleaning consumes a larger amount of ink than normal Cleaning. Perform Deep Cleanings only when necessary.
  1. In the Maintenance window, click 'Deep Cleaning'.
    Note: The layout varies depending on the printer and version of Windows you are using.
  2. When the Deep Cleaning window is displayed, select the target ink group for Deep Cleaning.
  3. Click 'Execute'.
    Memo: By clicking 'Initial Check Items' before clicking 'Print Check Pattern', you can see the specific confirmation items in Nozzle Check.
  4. When the confirming message is displayed, click 'OK'. (The Power lamp will blink green and Deep Cleaning starts. The blink stops when Deep Cleaning is over.)
  5. When Deep Cleaning starts, check the contents, and click 'OK'.
    Caution: To prevent interruption of the Deep Cleaning process, do not perform any other operations until Deep Cleaning is completed. When the operation of the printer is stopped, Deep Cleaning is completed. Deep Cleaning will take about 75 seconds.
  6. Print Nozzle Check again.
    Note: If the printed pattern is still not normal, perform steps 1 through 4 of the Deep Cleaning process one additional time.
    Caution: If after two Deep Cleanings the Nozzle Check Pattern is still not normal, turn the printer off and let it sit for 24 hours or more before attempting another Deep Cleaning again. The wait time may allow dried ink in clogged print head nozzles to liquefy, and resolve the problem
If this does not resolve the problem, please reply back and we'll try the next step ...
Don't forget to vote if this helps ... Cheers :)
2answers
My Canon S750 Bubble Jet Printer does not print with black ink. It seems to print all other colors though.
Replace and install the black ink cartridge with this Black Ink Tank BCI-3eBK Ifyou have done this and is still missing the black ink on print, clean the print heads. 1. Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'. 3. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
That should most likely work. If deep cleaning did not help, you may need to replace the print head.
4helpful
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
