Singer CE-100 Futura Computerized Sewing Machine Logo
Posted on Jan 12, 2008
Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
When I try to run the futura software I get a connection error. Check that usb cable is connected and power switch is turned on.
I've only completed four projects on my singer futura ce100. I don't think the cable should already be gone.
  • 8 more comments
  • Anonymous Feb 12, 2008
    You should have your local Singer Company check this out for you. I have a Singer CE-100 Futura and I love it. It isn't easy but once you learn it, it's wonderful. When I first got it I was only able to make a few easy designs. Then I couldn't get it to embroider at all. I would go through all the step and when it got to pushing the green button it did nothing. Fiinally I took it to the Singer dealer and he sent it back to the manufacturing plant and sure enough it was defective. If it is not doing what it is suppose to do when you follow the steps correctly, take it to someone to check it out!
  • Anonymous Feb 21, 2008
    I am trying to set up the sewing machine and computer for the first time. I get the message that the hardware is not found, check connections etc. when I go to the Singer support pages and check the drivers I do not have a 'tick' against the clem driver as described in the support. Very frustrating as I really want to get started with this machine. Help!
  • gin01 May 16, 2008
    I am having the same problem and this is the very first time I tried to get it set up just got the machine 5/15/08
  • Anonymous May 29, 2008
    the usb cord is connected and its saying that it not, I have restarted my computer, turned off the machine and restarted it ,took the usb cord and plugged it in another usb post but it still daying that the machine is not on and the usb cord is not connected
  • namewear May 30, 2008
    I have the same problem, I have restarted my computer, checked the usb cord
  • Anonymous Sep 16, 2008
    I have the same problem. It seems to me it's a driver problem. Of course, I wrote Singer and couldn't get any answer till now, let's wait and see. The Futura Support website has many functions / links not working.
    The update pack worked for me to install, but the computer is still not recognizing the CLEM driver that came with the CD. I think it can be two things. The driver can be too old or Windows XP must have some security patch removed. As soon as I (hopefully...) get a suppport message, I post it here.
  • Anonymous Dec 03, 2008
    I have the same problem anyone find a solution yet ... am also using gateway with vista home.
  • Anonymous Feb 05, 2009
    A friend gave me a singer futura ce100. He didn't have to drivers (main program) that came with it. I called singer....they wanted $100. Does anyone have this software they can send me? Please email me:
    [email protected]
  • rhonda phillips Apr 11, 2012
    is that for windows 7 i am having the same problem
  • ofaulkner618 Apr 24, 2014
    My machine is a Futura 400. I was sewing a pic and the lights all lit up and then it would not come back on when I tried to restart the machine. I am taking it to the repair shop in the morning and will let everyone know what he says.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13471
Points
9
So here's what I did and it worked for me. Somehow the WinDriver that is on the software is uninstalling itself and needs to be listed with the drivers for Jungo for this software to work. I installed the software when I first got the machine with no problems, then suddenly I couldn't open it and was receiving the same connection error. When you go to http://www.futura-support.com/faq/machine.htm#2 to install the drivers, you'll notice their screen shot shows both the CLEM driver and the WinDriver. Check your machine following their instructions to see if you have both listed under the Jungo driver. If not, go to http://www.jungo.com/st/windriver_usb_pci_driver_development_software.html and select the link under "Available WinDriver Toolkits" for your operating systems (I selected WinDriver USB for Windows). It asks a bunch of questions which I didn't know the answer to so I selected "other" on almost everything then entered "NA"or "?" for the other description. Select Download now and it will need to restart your computer. Once done, I looked at the device manager again and now WinDriver is listed under Jungo and CLEM and the software opens, no problems.
This will at least temporarily solve the issue, however, it's a free trial which means the download will expire at some point. Good news is, the windriver is on the futura disk, I just don't know why it's not installing or staying on the machine. I am sending all of this to Singer to figure out what they're missing in the installation files and hopefully get a fix permanently.
  • Anonymous Dec 05, 2011
    I am having the same problem, I hope this works for me.
    Thanks,
    RG
  • Pamela Joy Licatino
    Pamela Joy Licatino Apr 10, 2016
    I hadn't used my machine in so long, but when I decided to start again, I was getting the connection error and reordered a USB Cable. That didn't fix it. The problem wasn't with the machine or the software, it was me! When I reloaded the software onto my computer and another computer, I chose not to upload Jungo and that was where my problem was. I didn't feel comfortable uploading Jungo because I thought it was a program that was going to bring a virus in or allow more ads, but it was simply drivers that is needed. Thank you for addressing this and directing the help needed for crazies like me. I love my Futura Quintet!!!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13406
Points
I went to make a bridal gift and to sew my son's pants. Same issue which really sucks. I am going to see about getting a refund. This is a waste of money. This is definetly not worth wasting hundreds of dollars for.
Anonymous
Level 1:
New Friend:
  • Posted on Nov 13, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
19049
Points
I called Singer and they had me download the CE-250 patch off of the website (even though I have the 150) with the machine off and USB unplugged. Now it detects the machine, drivers, etc. and works great! They are very helpful if you have time to call - took me a 45 minute wait but worth it in the end!
Anonymous
Level 1:
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13406
Points
I am getting the message connection error check USB cable and make sure the power is turned on.
Both are OK I began this problem when I got a new Gateway with Vista Please download a driver or a solution.
1 Related Answer
Anonymous
  • Posted on Mar 09, 2009
SOURCE: Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
I received an email back from Singer stating that it is not possible at this time to load the Futura software on a 64-bit system using Vista. I have emailed to ask whether it would load if the OS were XP, but I haven't heard back yet.
They said that they were working on finding a fix for this, but they aren't sure that they will since it's a hardware problem.
I just got my Singer Futura Xl-400, I installed the CD yesterday. It asked me if I wanted to restart it so I clicked yes. Then I think my laptop crashed or something then it kept restarting itself. So I...
You did not indicate which operating system is used on your laptop. If you have Win Vista, 7, or 8, there is a patch that you can download from singerco.com, find your XL400, go to software and download the patch (should go to your download folder) . Next go to the Control Panel and uninstall the software. Re start your computer. Turn OFF your anti virus software and install the Base Singer software. Next, go to the download folder and double click on the Futura patch. Plug in your usb to the singer, then laptop, and turn on the sewing machine. At this point you can Launch the Futura software.
1. Turn on Computer
2. Plug in usb from XL 400
3. Turn on XL
4. Launch Software
Hope this helps - 8)
Singer Futura CE100 will not work with windows 8. Singer has no solutions. Any ideas?
Suggest to also install the earlier windows version that can recognize your CE100 software into your computer.
Futura software says machine isnt connected
Go to the Singer website and down load the driver for your machine.
1helpful
Singer futura ce200 usb cable not connected
IF YOUR WINDOWS 7 UPDATED TO 64 BIT, THE SOFTWARE WONT WORK ANYMORE
1helpful
I still get the connection error, but ck usb cable is connected and the power switch is on. Also error comes up cannot run an x86 build of this utility on 64 platform Initializing driver failed. says I...
This sounds like you have a problem with Windows 7 or Vista with the clem driver part.
First, there's a Windows 7 update available at www.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALL Futura software you've attempted to install and reboot your PC.
If for some reason this doesn't solve you're problem, I've posted a set of instructions at http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista that will allow you to run the software under XP on your Windows 7 machine. This is a bit more complicated a solution, but if you follow the instructions carefully, you should be fine. Try the Futura update first, though.
I hope this solves that problem.
Next, you say you're "still" having the connection error? Did I answer your problem before? I'm going to give you the answer to the problem I had with this, and if I already gave you this please leave me a comment on this. I check back daily, so I'll see it and we'll try and troubleshoot further from there. First, take care of the software problem. Next, make sure you're plugging the USB cable from the machine into a USB port in the BACK of your computer, not one of the front ports or a port on a USB hub. The cable and machine need more power than most of those ports provide, a technical detail that Singer doesn't realize. Good luck!
I dumped everything off computer and still cant get futura ce100 to open did what singer said several times still won't open and machine is on. Please help running vista.
Make sure your USB cable is plugged into one of the USB ports on the BACK of your computer. The front ports or a USB hub doesn't have enough power to run the USB cable for the machine. Singer doesn't have enough computer knowledge to figure this out-this was finally solved for me by a PC expert at work after I went nuts for a few months! Hope this helps!
2answers
When I try to open the futura program a pop up box continues to say check that USB cable is attached and machine is turned on. I tried two different USB Cables and turned the machine on. However the same...
My computer is extremely touchy when I use my usb cable to attach to my machine. I have to use the SAME usb port that I used when the driver was installed or else it will not recognize that my machine is plugged in. Basically it is telling you it cannot find your machine. Reinstall the driver and mark which usb port you used to install the machine.
Also, in order to open the futura software, your machine must be powered on and connected via USB cable before you attempt to open the software on your computer.
4helpful
5answers
Singer CE0100 Futura connection error....
Hi I had the same problem sent question to Singer and this was their reply
"Do you have Vista 32-bit or Vista 64-bits? Unfortunately the CE-100/200 machine will not be compatible with either Vista 64-bit systems or the newest Windows 7 computers. The CE-100/200 will only be compatible with Windows 98 through Vista 32-bit operating systems.
This appears to be a hardware issue and not something that we will be able to create a patch to correct. Drivers necessary for 64-bit operating systems are not compatible with the CE-100/200 machines." so I guess we are SOL
1helpful
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
