Question about Maytag MSD2454G Side by Side Refrigerator
Maytag msd2454gr refrigerator how turn filter light off after replacing filter?
  • Maytag Master
  • 4,656 Answers
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
Posted on Nov 23, 2009
6ya staff
SOURCE:
My Maytag MSD2454GR wont dispense water. What do i check first?
Check the filter status. If its OK most likely you have a bad solenoid water valve.
Mar 20, 2015 | Maytag Refrigerators
Have a maytag side-by-side frig..model # MSD2454GR...put a new filter in...how do you turn the lite that tells you need a new filter off?
you need to hold the lock and unlock plus the water button for 3 sec's and the light will go out ,
Jul 27, 2011 | Maytag Refrigerators
Maytag side be side model msd2454gr
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Burning smell coming from fridge maytag msd2454gr
Pull the refrig out and remove the back panel . On the side of the compressor , is the overload/relay . Carefully pry this piece off , as it will come off in pieces , due to burning . Part number 12002784 , is the replacement .
Nov 15, 2009 | Maytag MSD2456G Side by Side Refrigerator
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
I need to know what voltages and where to check for ice maker on maytag model msd2454gr not getting water to fill tray, do get water thru door.
120v on the harness to the imkr.... if your sure to be cautious unplug the frig and you'll have black, brown, white or blue, and green place a jumper wire between the black and brown plug back in and be sure you have something to catch the water from the fill tube if you get water from the tube you imkr may need replaced or repaired
Sep 06, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2454GR
compressor relay shot. needs ground wire to frame of fridge also.
May 18, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag msd2454gr
The click is not normal. The compressor is not starting and is tripping the overload. There is a chance the start relay on the compressor is shorted, but most likely the compressor will have to be replaced.
Unplug it for several hours until the compressor cools down and then try it again, if it starts up ok when it is cool the compressor is the problem for sure.
If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge.
Dec 07, 2007 | Maytag MSD2456G Side by Side Refrigerator
Maytag fridge made some clicking noises and then stopped cooling
For what it is worth. I had this problem twice and both times the compressor ad to be replaced. Ton this day it sounds like a pin pong game whenever it runs. No it is not the fans or the ice maker.
Nov 29, 2007 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
1,689 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
