This seems to be the problem of most of us
these days and some of our readers who wanted to know the methods how
they can remove the
Write Protected error from their
USB drives like
Pen Drives and
memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our
flash drives and even can’t
format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small
switch (if any, that you may have not noticed) at some place on the drive or
memory card reader. This is the prime reason for this error. If there is one, switch it to
the other side to turn the protection off.
• Yes I know this problem is also occurring these days without
this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “
low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some
virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your
pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the
low level format, you may need to “
Partition the drive“.
Dont worry, partitioning a pen drive means allocating it its File
System and Cluster Size that was lost after the Low Level Format.
For that:
- Run diskmgmt.msc in Run.
- In the disk management window, select the pen drive, right click on it and click on Format.
- Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in
this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
copy protected objects can not be removed
When I go to re-format my PNY Optima Attache 4GB Flash Drive it tells me that it is write protected. Thanks for any help.
hen y try to errase or writhe in my usb PNY-4GB-ATTACHE-USB-2-R54017 the system sayd : USB has write protected
it is protected
