This concerns a laptop with the age of 15 months.
8 months ago I had the same problem: all of a sudden the laptop switches off (even when only having Microsoft Word on) and restarts itself, and turns off, this repeatedly. People at the store adviced me to reset my computer. So i did. Never had that problem again, untill today. But the problem now is, I cannot get it on again. It used to stay on after a few times rebooting, but now it won't work anymore. What can I do to fix this? I could try the reseting again, however, I'd really like to transport my files to an external harddrive first! But now I cannot get it started anymore..... What do you advise?
Thank you in advance,
J.M.
I had this problem on an Acer Aspire 1670, the problem was that the vents on the fan cooler were blocked; hence it overheated and was shut down by the thermal controller, then cooled down a bit and restarted.
Try sucking out dust rubbish from the vents on the side with a vacuum cleaner else dismantel case and clean out with an air duster aerosol.
Besb
Have you try removing the battery and directly running on battery and also clean the ram and fixit it again.run the windows in safe mode and work for at lest houl an hour to chek you can go to safe mode by pressing the F8 key.if it is working in safe mode properly that means you need to check whether there is any virus .
