i need asssistance.i have a DFX 9000 that showing the " error oC " and beeping 5 times and all LEDs flashing .please help
Thanks people...thanks to you my problem is solved, thanks a lot....
I have encounted this problem on several occation.
Check to ensure that all the four fan on the printer are working fine.
Take note of MOTOR 2. The motor below main motor.
That should solve the problem.
Regards
Thanks guys...while checkinng of the above solution i found the left sprocket was disconnected from the board.connected it and the printer is working fine.cheers guys
SOURCE: DFX 9000 error oC
09 : FAN1 driver error
0A : FAN2 driver error
0B : FAN3 driver error
0C : FAN4 driver error
I have the same problem, just change the rom board and will solve your problem.
albert
no i have problem with cant change tracter settings, when i try to change it its showing locked.
