RCA HD52W59 HDTV Projection Television Logo
Anonymous Posted on Jan 10, 2008
RCA HD52W59 Projection TV
My tv is showing vertical lines any idea on how to fix it or what parts would be needed to fix it?
  • 3 more comments
  • Anonymous Jan 11, 2008
    Is that the convergence board? I saw a part number for the whole board of 264103. The wavey vertical line comes and goes. It is just one line so was not sure what it was
    Was not sure if I need to just get the Converance amp board which a referb is 264103R and the power Converance board. Should I get both or do you think the 1 will do the trick?
  • Anonymous Jul 26, 2008
    picture is concaved. images are triple, red, blue, green
  • dolphinluvr Jul 29, 2008
    my tv is doing the same thing as being concaved and red blue and green lines in it
  • antdog4321 Aug 13, 2008
    my picture is they exact same except i have many red, blue and green lines and three of them are thick wavy lines
A
Anonymous
Rca 52 inch d52w19byx2. It clicks 3 times and doesnt come on?
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Jan 10, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1710830
Points
8129
Convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
    yes thats it, how ever you can get it repair from ptscorp.com
    if it was me i would send it to ptscorp and get it repaired and if theres nothing wrong then you know it's the other board.
    otherwise i would get the amp board that has both the stk's on it
I have a RCA projection tv hd52w59 theres a partail static screen and a red green and a blue line in the middle
is the line horizontal or vertical ?
you have some sort of a deflection problem its either vertical failure or the yoke return circuit on the horizontal has a failure
At the top of TV there is a color line that is bowed it will not show a picture and another problem is the color. For example when it says menu on the screen you can see it in red, gren and blue not just...
Ur tv have a problem known as a convergence picture problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows picture or 3D pictues look alike?Yes.The tv convergence board it dead have to be fix like replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the convergence board to solved tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
I hane an RCA HD52W59 rear projection TV. When
The FBT,the flyback transformer is dead.Some the transitors in the deflection board is dead also.U know how to used a Ohm meter,and know soldering.Tries wesite like Tv repair World.com will help u to find the cause and replacement parts.
RCA HD52W59 I have horizontal lines that show up on the screen when there is a light colored background
It seems to be that your TV is a CRT. So you can fix this issue, you need to adjust a tube that's inside of the TV. This is something complicated, so what you will need to do, is to get a tech to go to your house so they can fix it.
Convergence Problem RCA HD52W59
you need to test all cables then make shure it is not your tv.
1helpful
4answers
I need a replacement tv screen for a rca hd52w59 itc222a
I have the 52" set of screens as well, if you still need them, email me @ [email protected] or just reply here.
Green lines? Greenish tint to black colors on tv
ohh noooo call a good repair man...
tap on the green crt and check for liquid on the board
Rca hd52w59 projection tv.
New conversion ic's sorry. Nothing else will work.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
