I was in the middle of a game on my PS3 when static noise sounded and green static appeared on the my screen. It appeared to be interference cause the screen did completely go. Then a few minutes later same thing but the screen went dark grey for a moment then came back. I'm using HDMI slots on PS3 & LCD. Any suggestion on how to resolve?
SOURCE: PS3 will not play any games
you have a bad drive u need to get it replace hopefully its under warrenty
SOURCE: xbox 360 showin black and grey specs on screen while playin
Unfortunately that sounds like a case of a 360's video card faltering - My suggestion is to locate your warranty ring microsoft and get a replacement.
Good Luck,
Blazamane.
SOURCE: PS3 static on screen
It sounds like you're carrying interference to your TV. Try moving you station away from any power source. Make sure your hdmi cable is away from any power as well. This may also be a ground issue. Plug your ps3 power brick into a different outlet.
SOURCE: My PS 3 has intermittent
It sounds like they told you to reset your video settings, here are the steps to do so again:
Make sure the system is off.
Hold down the Power Button for 5-6 seconds - until you hear the second beep.
That's it, your video settings are reset and you should be able to choose your input and configure it from there.
Testimonial: "Thanks for your help appreciate it"
