The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
i think there may be two reason.1/some setting may be worang-go on conttrol panel and chose printer and other hardwere. inside click mouse and look setting.2/ your touchpad driver may not be working properly. stall it next.
I recently acquired this problem after having my computer serviced. I have been using it for over a year with no difficulty. I read somewhere that this is a microsoft problem, one of their service packages. The question is, which one?
This is a well known occurance with laptops and is not something you can fix.
Occasionally the manufacturer will release a patch to try and help, but this is very rare.
try re-starting the computer; if that does not work install an external moue and try navigating withthat. If that works it is that the touchpad has been damaged; or the drivers arecorrupt
