Epson Viewsonic ViewPanel VE150M Monitor Logo
Posted on Jan 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer screen is white
Walked into the office today and the screen is white....i know the computer is working fine because i can log into it from logmein.com from another computer. I believe it may be something with the contrast or brightness, but I cannot change it back to normal...any suggestions are appreciated!
Anonymous
Level 2:
  • Expert 205 Answers
  • Posted on Jan 09, 2008
Anonymous
Expert
Level 2:
Answers
205
Questions
Helped
156306
Points
670
Here are the things I would try:
First, if you have another monitor I would plug it in to see if the problem is actually your monitor or something else. If you don't have access to another monitor then I would try to reset the monitor to factory defaults. I know this will not be easy because you cannot see the screen, but I looked at the manual and I believe this is how to do it:
Press the "1" button on the monitor, then press the downward arrow 6 times, then press the "2" button. I think this will reset the monitor. Take a look at the manual:
http://www.viewsonic.com/pdf/userguides/ve150m-1_ve150mb-1_ug_eng.pdf
And you'll see what I mean.
If that does not work, I would double check your cable connections (you have probably already done that). I woud then use Device Manager to make sure there's no known problem with your video adapter. To use Device Manager do this:
Right click on My Computer and select properties. Now select the Hardware tab and then click on Device Manager. Find the entry for your display adapter and verify there are not exclamation points or question marks next to it. If there are, let me know and we'll go a different route.
If the above does not pan out I would reboot the computer in Safe Mode to see what happens. Safe Mode loads Windows with a very minimal set of drivers including the most basic VGA driver available as opposed to the more capable one your most likey using now. If the monitor works in Safe Mode then it's most likely a software problem, but it does not totally rule out the possibility that the VGA hardware is going bad.
If it worked in Safe Mode then I would try a System Restore to a date before the problem began. To use System Restore do this:
Start->Programs->Accessories->System Tools->System Restore.
It's pretty self-explanitory and it will restore many critical files that may have become corrupted. It will take a while to complete, but it is reversible so you have little to lose.
If all of this fails to help then I would do whatever you need to find another monitor to plug in before you go any further. It could be a bad monitor after all.
Now the editorial section. I don't get paid for this. I know it's a strange hobby, but I like to help if I can. If you found any of this helpful I hope you'll give this post a positive rating. Nearly half of the solutions I've posted have never been rated. Thanks and good luck.
  • Anonymous Jan 10, 2008
    no comments, no questions, no rating....makes you wonder why any of us bother to answer questions...
  • hamid iqbal Oct 06, 2017
    1st check the video sours cable like vga r hdmi cable,
    2nd connect this monitor with another pc,
    if u can send picture of this monitor i think i can help you
Anonymous
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 88 Answers
  • Posted on Apr 02, 2012
Anonymous
Expert
Level 2:
New Friend:
Cheetah:
Answers
88
Questions
0
Helped
27687
Points
194
It would appear that I am not the only one who had a white screen problem. I say 'had' because I fixed the problem easily and everything is back to normal with colors and the elimination of non-responsive clicks on web pages with the white screen.
The White Screen of Death (WSoD), not to be confused with the BSoD, infiltrated my computer several weeks ago, and I finally eliminated the problem by changing my Back Ground Theme (which I had for years) in the Control Panel, Personalization, Windows 7, to another theme, "Blue Skies", which I downloaded from Windows' other themes.
I am amazed at my simple discovery, but it worked for me. I can't imagine why the first theme went bad, but I assume in through out the years, my updates, upgrades, changes, and downloads of other applications finally destroyed the integrity of the original theme.
This fix will probably work with any Windows theme and not just "Blue Skies".
Tom Irvine
North Charleston, SC
  • Anonymous May 20, 2013
    Many thanks for the suggestion - it worked for us!! The computer screen kept going white, but only for one user, so after changing the theme/background (we have windows XP) for that user - got a few seconds to do this before the screen went white, everything is back to normal. Thank you.
  • Anonymous Jun 16, 2013
    how did you open youre control panel if ti was white screen?
Do not know log in. Cannot log in on computer.
you have to be a little more specific with the questions , log into where , if you want to log into your computer , what kind etc, did you forget your id or password , most are the same , you have to know your password for your laptop , tell me more , cannot help until some more specifics on what are you locked out of , if is apple you can do a total reset (restore) fo to apple site and it will tell you how ,
One side of scan appears super bright to white , like the document is not touching the glass on that side . Why ?
  • Log on to the Lexmark website and update the driver. Also try and run diagnostics and see if that lists a fault.
My HP DV5 1159se was working fine last night and then this morning I go to turn it on as usual and a blank white screen comes up. The start tones are the same and I could even type my password in to log on...
If the inverter board or the back light behind the screen were bad your display would be blank, "but windows would be visible barely" the white screen indicates a bad LCD and must be changed. It is also possible the video cable from the motherboard to the screen has come loose and will need to be reseated back into place to fix it.
When it turns colors that usually means one of four things. 1 cable is not set write, 2 monitor is bad, 3 settings are out of whack or 4 the video card is going bad. I would try to mess with the cables and if that does not work plug that monitor into another computer to see if it work and plug a new monitor into that one. You should be able to solve what it is then.
Good luck
Computer recieved the blue screen of death but before....
turn it on with a/c and remove battery if it starts normal then the problem is from battery (TRY IT I HAD THE SAME PROBLEM)
REPLY THANKS
Screen becoming blue and flickering white
I fixed this same problem using a registry scanner. Here's a link to a good free one:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hope this helps.
ViewSonic VG170m 19 in. flat screen monitor
plug it in at the back of the monotor.....i left my connector undone and it fell out a LITTLE bit on one side of the connection and all i got was a blank screen also.
good luck
SCREEN IS ALL BLACK
First of all go for monitor self test. disconnect your monitor cable from the back of ur CPU and turn on ur monitor, if you see some colour(red, blue, green etc) boxes in any shape that means your monitor is fine, make sure colours are not hazy. If this succeeds that check the pins of the monitor connector, make sure pins are not bent or broken. Just Give it a try ... Cheers!!
Top Epson Computers & Internet Experts
Rob Hill
Rob Hill
Ngoro
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
