Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
This refrigerator has a thermoelectric cooler, no compressor. Anything that goes wrong is probably electronic. A circuit diagram would really be helpful.
Just in conversation, what you are referring to is the Peltier heating/cooling components. They are wired in parallel and require a power supply to activate them. These elements have 2 junctions, a hot side and a cold side. Depending on what temperature you you require, the polarities are reversed.Very possible,some of the junctions are faulty assuming you have checked the power supply. Best to replace all the peltier modules.
there is a 1000 Uf electrolytic capacitor on the power supply unit that was bought from a bad supplier. It's suffered a failure as they ALL did. Replacing it with a new 1000 Uf capacitor 16 volts or higher will fix it. Just remember they are polarity sensitive. i found mine at the dump and fixed it in less then 1 hour. The top of it will be bulging out and it could even leak
I have a Samsung fridge model no. RS2556sh. We lost power and when the power came back on the fridge did not. The LED is blinking in the top right corner and the lights or on inside the fridge but not cooling in either side. It doesn't sound like the compresser or any of the fans are coming on. So, what's wrong?
opj38 - Thanks, I used your hint/tip.!!! I have a Honeywell 88031, it was flickering the light, buzzing intermittently and not cooling. I took the back cover off and looked at the capacitor you mentioned. (Right by the Heatsink) It was bulged and buckled outwards. Marked 1000uF 16V I looked around in the junk parts I have laying around and found a 1000uF 10V Capacitor. I put it in and now it works normal and cools. I suppose I should get one rated for 16 or 25 V, but for now I am going to see if it will stay running or ? Good Luck to others with this problem.
Here we go folks, the problem is a failed capacitor on the circuit board.
It is called C10 which is printed on the circuit board, it is located on the left side of the silver heat sink and above the doughnut shaped coil, you should replace it with the same or one catagory higher in voltage.(1000 mircofarad 16 Volt)
You should have some soldering experience to replace and please pay attention to the polarity. (Pos and Neg.)
