Question about Schumacher & Fast Charge Starter Charger
I borrowed a friends and don't know how to read
I borrowed a friend's and don't know how to read the meter. As the needle goes upward, it seems to indicate a lower percent charge but more amps. I.e., when it's charging 6 amps, it looks like it has zero percent charge. It's a SE 82-6 charger Schumacher
    Guru:
  • 509 Answers
The meter goes down as it's charging.
Posted on Jan 03, 2010
    Problem Solver:
  • 4 Answers
NOT SAME ONE PROBABLY, but here's a pic of what i have.
http://www.northerntool.com/images/product/zoom_images/1677820.jpg
THIS MANUAL WILL HELP
http://www.batterysales.com/downloads/SE-82-6.pdf
hope this helps.
Posted on Jan 23, 2012
Anonymous
SOURCE:
DCR-HC26 Will not play/rewind/forward.Tried 2 identical cameras and cassetes. Nothing works.
Have you ever heard the silly phrase: "If everything else fails, read the User Manual"?
Please look on P. 23 where it says ... or better yet, here's the picture :-)
dcr-hc26-will-not-play-rewind#solution-section-izwbjt2504mgx4k4p1sstn4i-1-0.jpg dcr-hc26-will-not-play-rewind#solution-section-izwbjt2504mgx4k4p1sstn4i-1-2.jpg
Dec 22, 2014 | Sony DCR-HC26 Mini DV Digital Camcorder
I've borrowed a memorycraft 300e from a friend. I've used it without incident for a few days but suddenly without any issues now whenever I turn the machine on I get an error message
Did you check the needle down button. Be honest and return it. Price one and wonder why you borrowed something so expensive. She may know what to do. But dont tinker or try to fix it. It seems like a fixable error. You probably afraid to tell her. But you stressing yourself out. If you borrow it you probably know a cheap embroidery machine is about $500. Just get it back and maybe she won't snap its probably something simple.
Nov 03, 2014 | Sewing Machines
How do sew a straight line on a viking 6360?
You may need to service the machine. One thing to check is the feed teeth are at least 1mm above the needle plate on the highest setting. You can remove the needle plate and check if there is lint keeping the teeth from rising. The upper right knob controls the stitch length set it at 3 for normal sewing. 6 would be a longer stitch.
Jan 19, 2014 | Husqvarna Viking 1
I know thw primary chain tension is 5/8
Hi Gerald, You are absolutely correct 5/8" upward movement only is the min. cold measurement and the max. hot measurement. Get some sleep.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 22, 2012 | 2000 Harley Davidson FLSTC Heritage...
Cobra 148 gtl-st wont transmit but receives great
Check first your microphone
• check if TX is engaging when PTT is pushed.
• check for continuity ( mic and cable )
If you have not done these steps,
try it first, or borrow other compatible mic for Cobra 148GTL
from your friends on air.
Jul 28, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
How can I tell if electrical problem is alternator or battery on 1998 buick century?
Easiest way - You can connect a good battery to your car (borrow a friend's) - if it cranks over and stays lit - it's the battery. When it is running on the friend's battery - use an Amp meter to tell if the alternator is generating any amps. Just stick the probes up to the wires on the alternator and see if the meter moves. If it doesn't move you need a new alternator and regulator.
Amp meters are cheap and you can get one at Radio Shack.
Feb 14, 2012 | Buick Century Cars & Trucks
How can I tell hom many watts my cb radio is putting out
Hi, my name is John. you need a watt meter, you can purchase it at Radio Shack, or borrow one from a friend. You need a short three foot jumper. With the jumper end to your radio and the other end to meter, it will be marked on the meter. The other to your antenna. Put the meter on ten or twenty watt scale and key the mike. Your reading on the meter will be your watts or close to it.....hope this was very helpful.....Rate this solution on the four thumbs-up...John
Sep 08, 2010 | Radio Communications
Me and my friends halo 3 campang wont load
your halo 3 disc is scratched. I can't see how big the scratch is but a minor scratch will allow you to play some campaign missions. My suggestion would be to borrow a friends halo 3 disc and install it to your hard drive. This solution would allow you & your friends to play campaign together
Jun 13, 2009 | Microsoft Halo 3 for Xbox 360
I don't know how to load the film in?
Hi. This might be useful
http://www.youtube.com/watch?v=lCCCLagBKg8
May 16, 2009 | Minolta X-700 35mm SLR Camera
Battery not recharging.
Look on the charger itself & it will have the correct output voltage & polarity stamped on the charger. Then get a volt meter to verify if the correct output voltage is present. If the volt meter reads less than what is stamped on the charger, then I would recommend replacing the charger at that point.
Nov 20, 2008 | IBM ThinkPad T41 Notebook
Schumacher & Fast Charge Starter Charger  Logo
843 people viewed this question
Top Schumacher Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
Lisa
Lisa
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
