I cleaned and defrosted my fridge freezer ( Frigidare, Elite, model FR3009, serial number 004037978) a bit too vigorously. Now it is plugged back in it has failed to get cold again. The power light is on but fridge nor freezer is getting cold and I cant hear any noise like the motor. At the bottom at the back, there is a bundle of wires and box things. I think maybe something got disconnected here, but dont know what it is supposed to look like.
Can you help please?
Louise
Louise, this is a big area. I would switch off the fridge, look at the back where you see the" box things". You should see a timer which is white or black (wires comming out of it).. It has a short type of knob which can be turned manually clockwise.. Turn about a 1/4 turn then try and switch on again. If not, thermostat will be the problem. Assuming you never disrupted any wires.
Hello friend, thank you for your post!
In order to provide you accurate information could you provide me with your model number please? Normally you can locate the serial tag (which lists your model number) on the inside wall of your freezer. With that information I can provide you with the cubic ft. of your freezer. I look forward to helping you further. -Matt
